JoeM 9,975 #26 Posted December 6, 2019 Jim seen your thread on the fabricated deck and like it! I've had an 11 ga top plate bent and sitting in the corner for a couple years. Going down the same road as you. I do have a question. Those aftermarket spindles working out okay? I like that idea cause they are readily available Share this post Link to post Share on other sites
654jim 59 #27 Posted December 15, 2019 I have about 4 hrs on the deck now... so far, no issues. I did PUMP grease to the zerks till grease was oozing out both ends! Deck runs smooth and quiet! Share this post Link to post Share on other sites
Stormin 9,988 #28 Posted December 15, 2019 When I got my C-125 about 7 - 8 yrs back, the deck was in a right state. The top was well rusted. I got some 2mm sheet steel. Made a cardboard template off the top and made a new top. Still ok, but I do remove and clean it after use. The outer edges are starting to go now. I've since found 38" in very good condition. I'm saving that for future use. Good decks are hard to find over here. Share this post Link to post Share on other sites
AHS 1,675 #29 Posted December 15, 2019 What did you use for blades? Length? They look serious! 😄👍 Share this post Link to post Share on other sites
654jim 59 #30 Posted December 18, 2019 they are Gator blades removed from original deck... Share this post Link to post Share on other sites
Bill D 2,870 #31 Posted August 20, 2025 On 12/6/2019 at 4:27 AM, JoeM said: Jim seen your thread on the fabricated deck and like it! I've had an 11 ga top plate bent and sitting in the corner for a couple years. Going down the same road as you. I do have a question. Those aftermarket spindles working out okay? I like that idea cause they are readily available Did you ever make a fabricated deck? Share this post Link to post Share on other sites
