Chris G 3,382 #1 Posted September 23, 2019 I'm trying to find the part number for the transaxle drive pulley on my 1054. The original one is gone and I want to replace the cheap aftermarket one. Any help is appreciated. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #2 Posted September 23, 2019 What is the diameter of the pulley? 1 Share this post Link to post Share on other sites
Mikey the Monkey 701 #3 Posted September 23, 2019 1611??? Or is that the year Columbus sailed the ocean blue? 1 Share this post Link to post Share on other sites
Chris G 3,382 #4 Posted September 23, 2019 I honestly couldn't tell u they swapped it out with a two piece pulley and they changed the belt to fit. I discovered this by attempting to replace the belt and it is to loose now. I can't find a exact part number to refrence it to or anything. I will call a to z tomorrow as well but figured I'd try here as well just to see if it was known. I was recently told it may be 2707, but I can't confirm or deny that. Share this post Link to post Share on other sites
adsm08 4,771 #5 Posted September 23, 2019 (edited) According to the OM IPL the part number for that pulley in 2707. File #2, the 2.55 MB one, scroll down to the trans, #66 in the call out. Edited September 23, 2019 by adsm08 1 Share this post Link to post Share on other sites
953 nut 67,324 #6 Posted September 23, 2019 9 hours ago, Chris G said: The original one is gone and I want to replace the cheap aftermarket one. If you don't use a cast iron or cast steel pulley the cheap ones won't hold up. I can get you the measurements and a photo this afternoon. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,336 #7 Posted September 23, 2019 2707 pulley used on 953, 1054 and 1054A transmissions, ST-376, 6-1211 and 6-9111 snowthrowers Garry 1 Share this post Link to post Share on other sites
953 nut 67,324 #8 Posted September 23, 2019 The pulley is 6" OD and has a 3/4" hole. 1 Share this post Link to post Share on other sites
Chris G 3,382 #9 Posted September 23, 2019 Thanks to everyone for the help! Share this post Link to post Share on other sites
squonk 47,318 #10 Posted September 23, 2019 Lincoln at AZ probably has one.He had several 953 parts I needed. 1 1 Share this post Link to post Share on other sites
Chris G 3,382 #11 Posted September 23, 2019 @squonk thanks I didn't try to call him this morning. I guess there moving locations, or parts to a different warehouse this week. So I'll try him next week if no one replies to the wanted add before then. 1 Share this post Link to post Share on other sites
953 nut 67,324 #12 Posted September 24, 2019 Here are alternatives to consider, https://www.surpluscenter.com/Power-Transmission/Pulleys/Finished-Bore-Pulleys/5-95-OD-3-4-Bore-1-Groove-Pulley-1-BK62-C.axd https://www.surpluscenter.com/Power-Transmission/Pulleys/Finished-Bore-Pulleys/6-25-OD-3-4-Bore-1-Groove-Pulley-1-BK65-C.axd 1 Share this post Link to post Share on other sites
tractornut86 622 #13 Posted November 9, 2019 Did you ever find one? I have an extra original pulley. Share this post Link to post Share on other sites
