Olratlr 25 #1 Posted April 17, 2009 Will somebody help this old man out please? When I had to re power a Raider Nine a few years back the Tecumseh motor with the engine plate set about 1/2'' to tall so I made a bracket for the front of the hood to raise it up a little but where the hood latches it was a a crack on the sides where it didn't meet the dash panel. Can I lower the engine mount where it will sit level are will that change my belt length? Sorry about long post. :omg: Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted April 18, 2009 Well, you need to tell us what you repowered it with? and a picture or two might help solve your problem so we can see what your working with. there is alot of fine minds here and can solve lots of problems. Share this post Link to post Share on other sites
Olratlr 25 #3 Posted April 18, 2009 As stated above a Tecumseh it's a OH 140. Sorry no pictures Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #4 Posted April 18, 2009 You actually didn't previously mention what engine you used on the repower but I suspected an OHV when you mentioned hood clearance problems. The bottom end dimensions of the OHV engine are the same as the original HH-100 so you will need to use the correct riser (adapter) plate. The riser plate makes the frame to crankshaft centerline measurement the same as the big block Kohler which is what the belt guard and guides are designed to work with. As far as dropping the Tecumseh height.... you could probably do it - but you'll need to modify the belt guard, etc. It might be easier to find another hood and clearance it for the rocker box on the engine. The ironic part of it is that WH used an OH-160 on a C-160 8 speed (1-0385) in 1974 but due to the sheetmetal change (and possibly a different rocker cover/breather) it fit without using any special parts. (hood bulge, spacers, etc.) Share this post Link to post Share on other sites
Olratlr 25 #5 Posted April 22, 2009 You actually didn't previously mention what engine you used on the repower but I suspected an OHV when you mentioned hood clearance problems. The bottom end dimensions of the OHV engine are the same as the original HH-100 so you will need to use the correct riser (adapter) plate. The riser plate makes the frame to crankshaft centerline measurement the same as the big block Kohler which is what the belt guard and guides are designed to work with. As far as dropping the Tecumseh height.... you could probably do it - but you'll need to modify the belt guard, etc. It might be easier to find another hood and clearance it for the rocker box on the engine. The ironic part of it is that WH used an OH-160 on a C-160 8 speed (1-0385) in 1974 but due to the sheetmetal change (and possibly a different rocker cover/breather) it fit without using any special parts. (hood bulge, spacers, etc.) Terry Share this post Link to post Share on other sites
