TractorDude 7 #1 Posted September 19, 2019 I am restoring a C-105 WH and I would appreciate suggestions if anyone knows of any sources for 2 items; 1) replacement ‘T’ shaped rubber engine hood tie-downs, and 2) replacement engine mounts for the 10HP Koehler K241AS engine. Regards all 👍 Share this post Link to post Share on other sites
WHX?? 57,922 #2 Posted September 19, 2019 Might have to hold that info hostage in return for some The hood tie downs were on parts tree I believe or still available from a Toro dealer. Guessing you have a shaker plate? Check this thread out for the engine mounts. Unless you want to stay original? https://www.wheelhorseforum.com/topic/82967-new-solid-motor-mounts/?tab=comments#comment-816595 2 1 Share this post Link to post Share on other sites
Lagersolut 802 #3 Posted September 19, 2019 (edited) The original shaker plate mounts are still sold to the best of my knowledge and they aren't cheap 30-35 bucks each when I restored a C-101 few years ago- jacks has them https://www.jackssmallengines.com/jacks-parts-lookup/part/toro/108309 Edited September 19, 2019 by Lagersolut Share this post Link to post Share on other sites
SylvanLakeWH 32,289 #4 Posted September 19, 2019 I am redoing my second C105, although this one is a hybrid... I would suggest solid mounts. Try A to Z tractor under the vendors section. I just bought a bunch of stuff from him and he was quite good to work with... 2 Share this post Link to post Share on other sites
81blackhood 168 #5 Posted September 19, 2019 (edited) For the motor mounts use solid mounts from Zach Kerber. https://www.zkbrmachine.com/category/product/-188 Edited September 19, 2019 by 81blackhood 2 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,478 #6 Posted September 19, 2019 One Toro dealer https://www.psep1.biz/arinet.asp#/s/TO//106825/1/ Another https://www.partstree.com/parts/toro-106825/ Share this post Link to post Share on other sites
lynnmor 9,026 #7 Posted September 20, 2019 (edited) For latches, page thru this website They no longer have photos at each item, but there are photos if you look around the website. Edited September 20, 2019 by lynnmor 1 Share this post Link to post Share on other sites
dmoore 1,042 #8 Posted February 20, 2022 On 9/19/2019 at 5:19 PM, 81blackhood said: For the motor mounts use solid mounts from Zach Kerber. https://www.zkbrmachine.com/category/product/-188 Glad I found this thread. My C-101 needs the two front mounts. They were all new NOS back in 1997 when tractor was restored. I think the action of engaging the PTO had everything to do with it. The engine actually pulls back puling on the front rubber mounts. The rears are like new. From reading all the comments here over two years ago it will be the right decision. There's a reason this design was only used 2 years. I am a purist but when it comes to functionality I draw the line! Thanks AGAIN guy's! Share this post Link to post Share on other sites
dmoore 1,042 #9 Posted February 21, 2022 Set ordered! Share this post Link to post Share on other sites
redone 45 #10 Posted May 24, 2022 Guys. I am asking about the stops on those front mount brackets to keep the hood from falling forward to the ground. from what i see in these photos, mine looks the same. so what aim i missing? I have two 105. the same. thanks for your help. nice work on the shaker plate Share this post Link to post Share on other sites
SylvanLakeWH 32,289 #11 Posted May 24, 2022 Got a pic or two of your issue? Share this post Link to post Share on other sites
