TractorDude 7 #1 Posted September 16, 2019 Can anyone suggest a cause? If I try to move the lever to engage the PTO for the mowing deck, my Horse stalls. Is there an interlock somewhere that might cause this, or could it be a short somewhere in the wiring? Something is cutting out the ignition. I know this for sure because I am running an electric fuel pump which works great but power to that pump is cut if I move the PTO lever. Share this post Link to post Share on other sites
Ed Kennell 43,440 #2 Posted September 16, 2019 Check your seat switch. 1 Share this post Link to post Share on other sites
troutbum70 858 #3 Posted September 16, 2019 I would guess first it is the safety switch behind the dash at the pto lever or as Ed stated the seat safety switch. Most likely the safety switch at the pto lever. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,790 #4 Posted September 16, 2019 Welcome to the forum These detailed diagrams should help Garry Share this post Link to post Share on other sites
SylvanLakeWH 29,568 #5 Posted September 16, 2019 I love my C 105! In process of building another one...Love the Black Hoods! As noted above, safety switches are the likely culprit. Share this post Link to post Share on other sites
953 nut 62,643 #6 Posted September 16, 2019 8 hours ago, TractorDude said: I am running an electric fuel pump which works great but power to that pump is cut if I move the PTO lever. I presume the electric fuel pump is being powered from the ignition wire to the coil so if the coil has no power the pump also has a power loss. In the electrical diagram Garry furnished you will see that the power for the coil goes from the ignition switch to the seat switch then on to half of the PTO switch (in parallel) and finally to the coil. If there is weight on the seat (and the switch is working properly) the ignition will continue to receive power with the PTO in either position. Take a look at the wires going to the seat switch, chances are one or both have come off the connector or been cut, Share this post Link to post Share on other sites
TractorDude 7 #7 Posted September 16, 2019 Many thanks to those who responded. I found out it was the seat switch, one terminal had disconnected. Hooked everything up and it works great now!! 👍 4 Share this post Link to post Share on other sites
Ed Kennell 43,440 #8 Posted September 16, 2019 Excellent ….. Share this post Link to post Share on other sites
