"Manic-Mechanic" 1,486 #1 Posted September 15, 2019 (edited) I have been looking hard a set of these tri-rib tires. Thinking "I need to find a set of narrow rims?" Well, I hope to dispel this thought and maybe someone can help me here? Couldn't I get away with these mounted on the standard front wheel? Especially with tubes? Oldman Edited September 15, 2019 by oldman Share this post Link to post Share on other sites
ebinmaine 80,660 #2 Posted September 15, 2019 20 minutes ago, oldman said: Especially with tubes? That's the part that's going to help you put them on different types of rims. Using tubes of course will expand the tire a little further than just trying to catch the bead being tubeless. I'll check the width on Trina's Pony tractor in a little while. Hers is a 657 so it would have the narrow rims but I don't know why you couldn't put those on 70's vintage rim with a tube. 1 Share this post Link to post Share on other sites
RandyLittrell 3,945 #3 Posted September 15, 2019 If you save that pic and blow it up, you can see its not a picture of 4.80-8 tires. They 12 or 15's, I couldn't tell. 4.80-8's will fit what you want with tubes I'm pretty sure. Randy 2 Share this post Link to post Share on other sites
ebinmaine 80,660 #4 Posted September 15, 2019 I went out and measured the front wheels on Trina's Pony. The restored red tractor. She was going for a baby farm tractor kind of look on that one and she really wanted those 4.80 - 8 tri rib tires. The tires themselves are just about even with the rim and I think those are what you would consider to be a 3.5 wide rim so the actual width is about 4" to the outside of the lip. I have a 1974 or 5 C 100 here in the waiting to be restored section. That one has 6.5 wide tires but they bulge a bit on both sides so the rim is probably 4.5 or 5 wide. I see no reason why those tri ribs you want would not fit on a slightly wider rim such as what would use a 16 x 6.5 x 8. They would likely bulge out a bit on the sides. 1 Share this post Link to post Share on other sites
Lee1977 7,770 #5 Posted September 15, 2019 (edited) I put mine on 3" wide tub trailer rims, but I had to shorten the hubs as they were 4 1/4" wide and the later Wheel Horse front rims have 3 3/4" hubs. 3" or 4" wide rims work best with destone 400 x 8 . Greater Cleveland Tire has two 400 x 8 4 ply tri ribs for $37. I got my last Dec. I believe the tries and shipping was around $54. That was with out tubes, I already had tubes. Edited September 15, 2019 by Lee1977 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,486 #6 Posted September 15, 2019 (edited) 25 minutes ago, Lee1977 said: I put mine on 3" wide tub trailer rims, but I had to shorten the hubs as they were 4 1/4" wide and the later Wheel Horse front rims have 3 3/4" hubs. 3" or 4" wide rims work best with destone 400 x 8 . Greater Cleveland Tire has two 400 x 8 4 ply tri ribs for $37. I got my ast Dec. I believe the tries and shipping was around $54. That was with out tubes, I already had tubes. I see the trailer rims would be great! The front axle on the 1964-5 1045 are 4-1/2 long Edited September 15, 2019 by oldman Share this post Link to post Share on other sites
"Manic-Mechanic" 1,486 #7 Posted September 15, 2019 7 hours ago, RandyLittrell said: If you save that pic and blow it up, you can see its not a picture of 4.80-8 tires. They 12 or 15's, I couldn't tell. 4.80-8's will fit what you want with tubes I'm pretty sure. Randy I grabbed the picture on the e bay ad without even looking closer, good eye! Here is a more appropriate representation: 1 Share this post Link to post Share on other sites
RandyLittrell 3,945 #8 Posted September 15, 2019 1 minute ago, oldman said: I grabbed the picture on the e bay ad without even looking closer, good eye! Here is a more appropriate representation: I have bought quite a few pairs of them and thought they looked way too skinny. With tubes, I think you could spread them out on 6" wide rims. I think WH wide rims are narrower than 6" Randy 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #9 Posted September 15, 2019 Here's my set on the front of my 1067. There's a 4" x 8" rims with tubes. These don't have any bulge to them . 1 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,486 #10 Posted September 15, 2019 2 hours ago, The Tool Crib said: Here's my set on the front of my 1067. There's a 4" x 8" rims with tubes. These don't have any bulge to them . What is the width of your axle then on that Tractor? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #11 Posted September 15, 2019 Just now, oldman said: What is the width of your axle then on that Tractor? Not sure of the length but it has a washer and a color pen on the end. Share this post Link to post Share on other sites
Gordyhogg 150 #12 Posted December 16, 2019 (edited) Heres my deestone tri ribs on my commando 8 i love em and they look great, perform great, and the price was unbeatable. They are also 4.00 x 8 Edited December 16, 2019 by Gordyhogg 4 Share this post Link to post Share on other sites
123Go 6 #13 Posted March 30 (edited) Well' better late than never I'm told..lol I hope this helps someone in the future. My 414-8 fronts are Deestone Easy Steer Tri-Ribs (4x8). Wheel Horse GT rims I think?? Sorry I bought my rims off EBay yrs ago. If you look for narrow rims you might watch out for wheels with the steel center caps (tapered bearings). I have two sets, they're 8" rims & like 3 1/4" & 3 1/2" width bead to bead. Other members here might know other narrow sizes & tractors they came on, idk? Most front rims are 4" to 5" wide though. I prefer the WH rims with tapered bearing like older Cars/Trucks, Campers, Boat trailers etc.. The center axle hole size can be changed out via bearing size if one chooses, so it could fit 3/4, 1/2 axle dia if needed? Smoother rolling wheels & their center hole dont wear out & wobble like a non bearing wheel with age, just the bearing will so its a cheap fix. Tapered bearings are tougher than a reg ball bearing setup, its built for highway speed, higher heat & pothole abuse. Just saying. If you find them grab them. Fyi- Deestone Easy Steers high center rib raises your tire up on the harder surfaces so a tractor turns one handed. But in mud/soft dirt the ribs sink in so the tire grips instead of sliding across the top of the soil. My Rears are Carlisle Super Lug 23x9.50x12 or so I think? Not near it to see, never been off so idk actual Rim Width? I traced the letters with a white Paint marker so don't go searching for white letter Super Lugs. lol I put bolts though the back side of my hubs & use (chrome) Lug nuts on front side. Much easier to install my wheels, its like fitting car rims on the rear now. Hope this helps, sorry long! Edited March 30 by 123Go 4 1 Share this post Link to post Share on other sites
