Dennis C. 142 #1 Posted September 11, 2019 Just picked up a 1owner 1979 C-101. Runs, drives and cuts. Although garage kept the tractor does have surface rust on the hood . Probably won't repaint. Are gas caps with the gauge still available? Also tying to download a parts manual but no luck. Any models similar? Thanks. 1 Share this post Link to post Share on other sites
Pullstart 68,633 #2 Posted September 11, 2019 Dennis, a google search led me to Jack’s small engines. Is this what you’re looking for? https://www.jackssmallengines.com/jacks-parts-lookup/part/toro/106945?gclid=eaiaiqobchmi7u60uddj5aivrwogch0yqgdzeaqybsabeglgg_d_bwe Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,920 #3 Posted September 11, 2019 There is a parts list in this group of files. Look through them all because there is no order to them with this type of link https://www.wheelhorseforum.com/search/?&q="1979 c-101"&type=downloads_file&search_and_or=or Garry 1 Share this post Link to post Share on other sites
Dennis C. 142 #4 Posted September 11, 2019 Thanks or the info. I have a friend that needs one of those gauges as well. I'll save all the files on the C-101. Thanks for your help!! Share this post Link to post Share on other sites
Burnerman 759 #5 Posted September 11, 2019 Where’s the picture!! I love my 78 C101. 2 Share this post Link to post Share on other sites
peter lena 9,642 #6 Posted September 11, 2019 dennis c , welcome to the site , if that hood is not really rusted , you could try using some spray lubricant oil ( your choice ) on a rag and slowly rub it on the paint , it will usually cut thru the crud and start to show paint life. i have done this with very good results , you can leave the oiled look on it ,or next step would be to lightly buff it out with a paint cuter, showing solid paint and shine. good luck with it , pete 1 Share this post Link to post Share on other sites
oliver2-44 11,137 #7 Posted September 12, 2019 Check out the "isavetractors web site he has the gas cap/gages Share this post Link to post Share on other sites
tunahead72 2,597 #8 Posted September 12, 2019 3 hours ago, Burnerman said: Where’s the picture!! I love my 78 C101. Is that another shot of your new solid motor mounts? Nice looking tractor, now if we can just get @Dennis C. to show us his... Share this post Link to post Share on other sites
Burnerman 759 #9 Posted September 12, 2019 5 hours ago, tunahead72 said: Is that another shot of your new solid motor mounts? Nice looking tractor, now if we can just get @Dennis C. to show us his... Yes. I love tractor pictures. @Dennis C. where’s yours?👀 Share this post Link to post Share on other sites
Dennis C. 142 #10 Posted September 12, 2019 Thanks for all the reply's and info. Nice looking tractor!!! Can't afford to redo mine, although it would be a great candidate. As I mentioned in my first post, I bought this from the original owners family. The seat is worn and the knobs for the throttle and choke are missing. The gas tank gauge works but the plastic lens is broken. The owners son delivered the tractor yesterday and I took engine degreaser and cleaned and power washed e the entire tractor. Other than the rust on the hood the overall condition of the tractor is good. Brake and clutch need adjustment but I think I know what is causing the problem. The space between the tranny and seat pan was packed solid with grass clippings. May not have been cleaned in years. I removed the seat and fender pan and the grass was packed so tight the shift lever couldn't moved freely. Today i will roll the tractor outside, remove the rear wheels and power wash the grass out. Then I should be able to check on the clutch and brakes. Here is a picture of the tractor as it was delivered yesterday. It has since been power washed and all the oil has been cleaned up. I'll post another picture later. Anyone know where I can find a seat? 7 1 1 Share this post Link to post Share on other sites
Dennis C. 142 #11 Posted September 12, 2019 anyone know where I can get a seat for this Share this post Link to post Share on other sites
peter lena 9,642 #12 Posted September 12, 2019 seats are easy to find on the net, just verify that your w/h bolt pattern size will match up, on the other hand , if you have to have an original w/h seat , that will cost you more and finding one can be difficult, tractor supply has a limited amount of seats, i have bought mine from agri,fab . with exact matching seat bolt on pattern , shown on their site , pete Share this post Link to post Share on other sites
Dennis C. 142 #13 Posted September 12, 2019 Thanks Pete. I'd really love to bring this tractor back but without a proper place to work and equipment, the cost is just too prohibitive. Outside services for sand blasting and painting are expensive. I had a set of WH rims sandblasted and painted and that was $140. The hood was $250. Still this tractor will be in a garage, out of the elements. Share this post Link to post Share on other sites
oliver2-44 11,137 #14 Posted September 12, 2019 If you want to keep that tractor original, but spruce it up, that tractor looks like a great candidate to wet sand and clear coat. Tractor Supply and Norther tool have good seat if you catch a sale. Also "Surplus Center" on the web has some nice seats. Share this post Link to post Share on other sites
RandyLittrell 3,943 #15 Posted September 12, 2019 You would be amazed at how that will look with a little polishing and detail work! Randy 1 Share this post Link to post Share on other sites
81blackhood 168 #16 Posted September 12, 2019 4 hours ago, Dennis C. said: anyone know where I can get a seat for this I got mine from Northern Tool. https://www.northerntool.com/shop/tools/product_7687_7687 1 Share this post Link to post Share on other sites
Dennis C. 142 #17 Posted September 12, 2019 I was just looking at those. Did you have to make a adapter to bolt the seat in place? Thanks BTW, what color and brand of paint did you use? Share this post Link to post Share on other sites
Burnerman 759 #18 Posted September 12, 2019 Mine was just sprayed with Rustoleum. You don’t need to sand blast a thing. That tractor looks a lot better then mine when I got it. Wash it off, dry it and then Oil everything!! Wipe it down with an oily rag and it’ll be fine. I just went through all the moving parts and replaced worn belts, pulleys and bearings. Clean up the engine and fuel system and add fresh filters. You don’t need a lot of money to keep that horse in good working order for many years to come. 2 Share this post Link to post Share on other sites
81blackhood 168 #19 Posted September 12, 2019 1 hour ago, Dennis C. said: I was just looking at those. Did you have to make a adapter to bolt the seat in place? Thanks BTW, what color and brand of paint did you use? The seat is a direct fit. The paint is Rustoleum Regal Red Share this post Link to post Share on other sites
Burnerman 759 #20 Posted September 12, 2019 1 hour ago, 81blackhood said: The seat is a direct fit. The paint is Rustoleum Regal Red For comparison my seat was also a direct fit and it’s Rustoleum Sunrise red. Share this post Link to post Share on other sites
Dennis C. 142 #21 Posted September 13, 2019 Thanks for all the help guys. Are there any pictures of the PTO clutch setup for this Tractor? The previous owner has a big spring attached at the adjustment screw/retainer. Is that suppose to be there? Thanks again. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,920 #22 Posted September 13, 2019 This item 13 spring? Garry Share this post Link to post Share on other sites
Dennis C. 142 #23 Posted September 14, 2019 Thanks for the diagram, guess that is the correct spring on my PTO. Share this post Link to post Share on other sites
Burnerman 759 #24 Posted September 14, 2019 17 hours ago, Dennis C. said: Thanks for all the help guys. Are there any pictures of the PTO clutch setup for this Tractor? The previous owner has a big spring attached at the adjustment screw/retainer. Is that suppose to be there? Thanks again. 1 Share this post Link to post Share on other sites
Dennis C. 142 #25 Posted September 15, 2019 Thanks Burnerman for the detailed pictured. My spring attaches to the top of the PTO clutch actuator. I found a schematic of the exploded view and mine is suppose to attach that way but that spring certainly exerts a lot of side load on the shaft. I like this set up better. 1 Share this post Link to post Share on other sites
