CCox 8 #1 Posted September 9, 2019 I have decided to fabricate a deck over the winter that will utilize the spindles, hanger and wheels from my stamped 42" rear discharge deck. The last one I made was for a Scag zero turn and it restored new usefulness to that unit. Similar to my last one, my plan is to lay out in CAD, the current size, approximate shape and openings of the current deck. Then I send my drawing to a waterjet service and they cut the layout from 3/16" steel plate. Then I weld the pieces on a welding table. Once finished, I will prep, prime, paint and then transfer my wheels, hanger and spindles to the new deck. I think the rear discharge decks lend themselves well to this because they are symmetrical. Once the layout is completed, the material cost and welding time is the only repetitive cost if I were to make more than one. Anyone interested in these? Any wish list? Obviously, a prototype would be nice to see but I can't take time from mowing to disassemble my weekly mowing equipment until the season is finished. Just tossing out the idea and gauging interest. Thanks. 4 Share this post Link to post Share on other sites
Burnerman 759 #2 Posted September 9, 2019 (edited) I’ll beta test a shell for you! 😁😁 I thought about fabbing up a deck but it’d be so expensive. I’d like a 3/16” leveling/ reinforcing plate that tied all 3 spindles together on the same plane. That could be easy to jet out if I had access to one. I could bolt it down from the top of my old deck shell to the spindles. Edited September 9, 2019 by Burnerman Share this post Link to post Share on other sites
Stepney 2,356 #3 Posted September 10, 2019 It wouldn't be cheap, but we can't really get them anymore either.. write me up for the interested party. Share this post Link to post Share on other sites
pacer 3,180 #4 Posted September 10, 2019 For what its worth ---- I have a MF 1650 GT and the 48" deck was rotten so I put out a ad asking for a replacement shell and ended up with a home/shop? built deck. It was very nicely done and looked exactly like the original ..... its one draw back is its HEAVY!! Decks can be a bit of a pain to remove/replace anyway and this thing is really a booger. I finally figured out to raise deck high as will go and jack the whole tractor up til a furniture dolly will slide under the deck. I then lower the deck to sit on the dolly, disconnect and pull it out on the dolly. Share this post Link to post Share on other sites
CCox 8 #5 Posted September 10, 2019 5 hours ago, pacer said: For what its worth ---- I have a MF 1650 GT and the 48" deck was rotten so I put out a ad asking for a replacement shell and ended up with a home/shop? built deck. It was very nicely done and looked exactly like the original ..... its one draw back is its HEAVY!! Decks can be a bit of a pain to remove/replace anyway and this thing is really a booger. I finally figured out to raise deck high as will go and jack the whole tractor up til a furniture dolly will slide under the deck. I then lower the deck to sit on the dolly, disconnect and pull it out on the dolly. Pacer, Agreed and thank you for the info. I made my first from 1/2 plate and while it is extremely sturdy, its a bear to wrestle into position. Its also 54" wide and better than 36" front to back. I still like thicker steel but in hindsight, the deck could have been 3/16" and would have been fine. My supplier had the 1/2" as a drop (leftover) and I got it cheaper than had they cut the same size in either 1/4" or 5/16". I will build my first prototype and evaluate. Share this post Link to post Share on other sites
ronhatch 410 #6 Posted September 11, 2019 (edited) Why can't deck shells be made using 12 ga. stainless steel? I made a couple of extra long front baffles out of 14 ga. SS to improve mowing performance and they worked out great. Edited September 11, 2019 by ronhatch Share this post Link to post Share on other sites
Stepney 2,356 #7 Posted September 16, 2019 On 9/11/2019 at 9:24 AM, ronhatch said: Why can't deck shells be made using 12 ga. stainless steel? I made a couple of extra long front baffles out of 14 ga. SS to improve mowing performance and they worked out great. Just curious, what do you mean by 'front baffles'? Share this post Link to post Share on other sites
Burnerman 759 #8 Posted September 17, 2019 32 minutes ago, Stepney said: Just curious, what do you mean by 'front baffles'? this is my old rusted out 1978 42” rd deck. It had these baffles welded in the deck. My newer deck doesn’t. I believe this is what he’s talking about. Share this post Link to post Share on other sites
Stepney 2,356 #9 Posted September 17, 2019 9 minutes ago, Burnerman said: this is my old rusted out 1978 42” rd deck. It had these baffles welded in the deck. My newer deck doesn’t. I believe this is what he’s talking about. Ah yes, for some reason I was thinking SD, not RD. Yes one of my older RD decks has the front baffles just like that. Never could tell if it made much difference or not. Share this post Link to post Share on other sites
CCox 8 #10 Posted September 17, 2019 Correct on the baffles. I have had them with and without. I think the version with distributes the clippings more evenly. Preliminary check on stainless prices, weld time, etc.... looks cost prohibitive. Will have steel options once grass and leaves are done. Share this post Link to post Share on other sites
ronhatch 410 #11 Posted September 18, 2019 I was talking about a SD 42" deck. It wanted to blow a certain amount of clipping out the front until I fabricated a front baffle out of SS that hung about a 1" lower then the front of the deck. It also had about a 3/8 to 1/2"" lip that pointed toward the blades. It solved the problem and works great. Share this post Link to post Share on other sites
Stepney 2,356 #12 Posted September 18, 2019 13 minutes ago, ronhatch said: I was talking about a SD 42" deck. It wanted to blow a certain amount of clipping out the front until I fabricated a front baffle out of SS that hung about a 1" lower then the front of the deck. It also had about a 3/8 to 1/2"" lip that pointed toward the blades. It solved the problem and works great. Exactly the problem Im fighting with mine I use for leaf season. So its just a lip off the front of the deck that points rearward? Ill have to try that. Share this post Link to post Share on other sites
654jim 61 #13 Posted September 19, 2019 Just finishing up a Fabricated 42" sd.. Got a buddy with a cnc plasma cutter,, and 4 hrs of shop time got me THIS! 10g. steel top and sides... 14g baffles.. reused all brackets and wheels. Sourced new spindles and pulleys on #bay. 6 5 Share this post Link to post Share on other sites
654jim 61 #14 Posted September 19, 2019 (edited) My spindles were trashed... I was able to get center spindle apart, but messed up the threads on the outers. My bigger hammer method didn't work to remove pulleys,,. So, I modified the deck depth to accommodate "replacement" spindles, pulleys for a cubcadet 1045.. $80 for 3, including the pulleys! My friend says material costs are app. $60... says we'll work something out for LABOR!! Good to have talented FRIENDS!!! Edited September 19, 2019 by 654jim 2 Share this post Link to post Share on other sites
Stepney 2,356 #15 Posted September 19, 2019 24 minutes ago, 654jim said: My spindles were trashed... I was able to get center spindle apart, but messed up the threads on the outers. My bigger hammer method didn't work to remove pulleys,,. So, I modified the deck depth to accommodate "replacement" spindles, pulleys for a cubcadet 1045.. $80 for 3, including the pulleys! My friend says material costs are app. $60... says we'll work something out for LABOR!! Good to have talented FRIENDS!!! That thing is a beauty.. and I'll bet it wont warp so easily as the original 42"s did.. Share this post Link to post Share on other sites
ronhatch 410 #16 Posted September 19, 2019 (edited) That looks great! With the smaller upper center drive pulley it looks like you're going to speed it up too. Now replace the wheels with a roller across the back for that ball park look. Edited September 19, 2019 by ronhatch Share this post Link to post Share on other sites
654jim 61 #17 Posted September 19, 2019 (edited) Good catch on the smaller drive pulley... Its actually a 4 1/4" vs 4 1/2" original. My math tells me a 220rpm increase... Should help! The 5" blade pulleys make it look smaller than it is! Been mowing with my 654, since the 312 is being repaired. Edited September 19, 2019 by 654jim Share this post Link to post Share on other sites
Bill D 3,093 #18 Posted April 29, 2025 On 9/18/2019 at 9:13 PM, 654jim said: Just finishing up a Fabricated 42" sd.. Got a buddy with a cnc plasma cutter,, and 4 hrs of shop time got me THIS! 10g. steel top and sides... 14g baffles.. reused all brackets and wheels. Sourced new spindles and pulleys on #bay. Old thread I know, but has anyone else done something like this? I'm curious if any vendors have considered building new shells? Thoughts? 1 Share this post Link to post Share on other sites
betaxe 7 #19 Posted July 26 did anyone make a cad drawing for the 42" rear discharge mower deck ? i got a 312-8 the other day and the deck is in bad shape and dont want to do a lot of rust repair to it. i currently work at a place where we have a laser cutter here in denmark so i want to cut my own but if anyone has made the cad drawing im willing to buy it because im lazy my mower is a E5 42mr01 Share this post Link to post Share on other sites
peter lena 10,013 #20 Posted July 26 @654jim @CCox @Burnerman like the build / make ups , my question is ? what did you use for the lubricant in all related bearing spindles ? hope you ENHANCED THAT AREA LIKE THE DECK BUILD UPS , tell me YOU DID NOT , COUNT ON ORIGINAL LUBE IN THOSE BEARINGS ? known for whyining , and early failure , none of my decks have baffles , but all have this regular , GRUNGE CYCLE BREAK , also store them after season , up against a wall beam , oiled down over winter . decks are permanently stained black , oil slick , nothing sticks , cut at highest setting , every related , bearing , has lucas x tra hd green chassis grease , after total clean out , 550 deg flash point , polyurea rated , never had a failure or pto clutch disc burn out . pete l Share this post Link to post Share on other sites
Stan50 218 #21 Posted July 27 I'm thinking about get rid of these front baffles, to much dirt and debris there. I clean underneath of the deck often but these baffles driving me nuts Share this post Link to post Share on other sites
peter lena 10,013 #22 Posted July 27 @Stan50 I refer to those baffles as , rot boxes , because thats what they are , trapped moisture packed grass , will eat a deck alive . why not eliminate it ? oil soaking deck , BREAK THE ROT CYCLE , all of my decks have this , zero rust or rot , regular maintenance , and cleaned out bearings , and refill with lucas xtra hd , green chassis grease , 550 degree rated / also polyurea rated , stays with bearings , never had a bearing failure or whyining noise . pete 1 Share this post Link to post Share on other sites
Stan50 218 #23 Posted July 27 @peter lena You've convinced me I was wondering what maker meant? I'll cut these baffles out after mowing season and I protect with oil. Share this post Link to post Share on other sites
peter lena 10,013 #24 Posted July 27 @Stan50 thank you for the reply ! my main outlook on REPEDITIVE ISSUES / PROBLEMS , is how can I eliminate this from happening again ? realise that for the purest , it simply cannot be done , yet the issue remains . rot box removal , with small circular cutting wheel , makes it very easy , always cut at highest setting for better discharge , none of my oiled decks , retain any grass at all , that sun got oil staining , fusion , for many hours , really sets your slick , moisture resistant base . also wall mount the decks , standing on wheels up against wall over winter , with an inspection and chain and cable spray , sun hot for metal absorption, open gear aerosol , dries like slick armour , in heat , all experiments , combine that with , lucas green x tra hd chassis grease in every related , cleaned out bearings , guess what ? no rust / rot / buildup , decks run with total ease , no whyining bearings , or screaming , pto lever engagement . every stage based on , repetitive failure , often just a small verification , of function . check out lucas xtra hd green chassis grease , specs , 550 deg , polyurea , ant sling , no bearing failure / noise . pete 1 Share this post Link to post Share on other sites
