ebinmaine 75,842 #1 Posted September 9, 2019 The engine that is in Trina's Pony Horse temporarily is a 1978 or 9 Briggs 8 single. Aluminum block. The drain plugs in the base are one on each side of the engine. Both cast iron. 1 seeps a bit but I don't dare to over tighten it for fear of stripping the aluminum. Any suggestions? Share this post Link to post Share on other sites
JoeM 9,327 #2 Posted September 9, 2019 Teflon tape, but keep it from extending into the crank case. Might help. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #3 Posted September 9, 2019 Teflon tape or some type of thread sealant paste. Share this post Link to post Share on other sites
ebinmaine 75,842 #4 Posted September 9, 2019 Thanks for the fast response has guys! Kind of thought Teflon tape was not friendly with dinosaur petroleum products? Or is that only just gasoline? Share this post Link to post Share on other sites
JoeM 9,327 #5 Posted September 9, 2019 used it on many hydraulic systems, works good with oil. Share this post Link to post Share on other sites
Stike 204 #6 Posted September 9, 2019 I've wicked pipe thread using cotton string wrapped in the Male end and threaded the part in, helps seal imperfections and holds up to heat pretty good, or if you can use the other plug jb weld starting about 3 threads down should work. Share this post Link to post Share on other sites
squonk 44,918 #7 Posted September 9, 2019 Blue Monster or Retcorseal pipe thread sealant. 1 Share this post Link to post Share on other sites
ZXT 2,401 #9 Posted September 10, 2019 Teflon is used on fittings and sending units that are screwed into oil passages on all old cars. I'd wrap some on the plug and call it a day! Share this post Link to post Share on other sites
