WHwest8597 85 #1 Posted September 3, 2019 I'm looking for a 3/8 inch drive impact socket to change blades. Any recommendations. I bought the new 12 volt DeWalt 3/8 impact. I found it being smaller is easier to get under the decks when using ramps. Share this post Link to post Share on other sites
pfrederi 19,955 #2 Posted September 3, 2019 I do not think you will find a 1-1/8" socket with 3/8 drive you will need a 3/8-1/2 adapter 1 Share this post Link to post Share on other sites
roadapples 6,987 #3 Posted September 3, 2019 I use a socket and a breaker bar with a block of wood to hold the blades.... 4 1 Share this post Link to post Share on other sites
Burnerman 759 #4 Posted September 4, 2019 On 9/2/2019 at 9:05 PM, roadapples said: I use a socket and a breaker bar with a block of wood to hold the blades.... ^^^ that and I remove the deck and clean it too. It’s a lot easier to work on off the tractor. I also doubt that 12v Dewalt would have enough power to take off blades. I certainly wouldn’t trust it to tighten them enough. 3 Share this post Link to post Share on other sites
The Tuul Crib 7,347 #5 Posted September 4, 2019 20v Dewalt with a half inch drive is what l use. Works well for me. Share this post Link to post Share on other sites
Retired Wrencher 6,478 #6 Posted September 4, 2019 WHwest8597 Just make sure you do not over tighten the nut. Get most of the way then use a breaker bar for real feel of being tight. I damaged spindle one time but using an impact. Just my. 1 Share this post Link to post Share on other sites
ohiofarmer 3,383 #7 Posted September 6, 2019 When I have a thin profile nut and use an impact--especially on a nut that goes on and off a number of times, it pays to pay attention to the leade of the socket. Manufacturers vary, but Pittsburgh are among the worst If all you have is a cheap socket just use a six point and grind off the end a bit so it grabs the nut fully . I have a blade,oil pan,and a 9/16 with modified ends. They also make special stuff for rounded bolts . They have a perfectly flat end which proves the point. 1 Share this post Link to post Share on other sites
