GreenMntRanger 38 #1 Posted September 1, 2019 Need a source for an ignition relay for a 418C. An electrical schematic would be great to. Yes, I admit my Serch Fu is weak today Share this post Link to post Share on other sites
953 nut 64,680 #2 Posted September 1, 2019 Attached is the manual that covers your 418-C. If you are referring to the starter solenoid (pictured below) they can be purchased at any auto parts store or Tractor Supply. Share this post Link to post Share on other sites
Achto 31,337 #3 Posted September 1, 2019 6 hours ago, 953 nut said: If you are referring to the starter solenoid (pictured below) they can be purchased at any auto parts store or Tractor Supply. @GreenMntRanger, If your go to Oriely's or some other chain auto parts store, you will most likely get a confused look when you ask for a starter relay for a Wheel Horse. Here is the cure for that.. Ask for a starter relay for a 1978 Ford F150, engine size does not matter. This will get a relay that will work. 1 Share this post Link to post Share on other sites
953 nut 64,680 #4 Posted September 1, 2019 If you do use a Ford solenoid do not use the "I" post. 1 Share this post Link to post Share on other sites
pfrederi 20,067 #5 Posted September 1, 2019 (edited) They also can be purchased at Lowe's Home depot for small $$ or even cheaper Surplus center I have used a couple of these work just fine Edited September 1, 2019 by pfrederi 1 Share this post Link to post Share on other sites
