Stormin 9,987 #226 Posted November 27, 2019 I would think, if properly sealed where they fit and the gauge glass it's self, then I don't forsee a problem. 1 Share this post Link to post Share on other sites
19richie66 17,808 #227 Posted November 27, 2019 1 hour ago, ebinmaine said: @PeacemakerJack Awesome idea on the Richie cup. We have a couple here. I see a photo op in the future. Hope to get some more going soon. Had to pack all the stuff away for a bit. 2 1 Share this post Link to post Share on other sites
oliver2-44 11,212 #228 Posted November 27, 2019 You might consider some of the digital gauges available on flebay 2 Share this post Link to post Share on other sites
ebinmaine 77,322 #229 Posted November 27, 2019 24 minutes ago, oliver2-44 said: You might consider some of the digital gauges available on flebay I was thinking the same thing but I really like the look of the old analog stuff 1 Share this post Link to post Share on other sites
Lee1977 7,551 #230 Posted November 27, 2019 Here is an ideal, don't know if it will work for you. First If you don't need the rectifier located below the dash. I mount a gauge in a 2" abs pipe below the dash. 1 Share this post Link to post Share on other sites
ebinmaine 77,322 #231 Posted November 28, 2019 2 hours ago, Lee1977 said: If you don't need the rectifier located below the dash The one currently mounted on the engine may very well stay there. That would leave that space on the tractor free as well. Absolutely something I'll keep in mind. Share this post Link to post Share on other sites
Pullstart 68,872 #232 Posted November 28, 2019 17 hours ago, Lee1977 said: Here is an ideal, don't know if it will work for you. First If you don't need the rectifier located below the dash. I mount a gauge in a 2" abs pipe below the dash. More detail on that exhaust please? Share this post Link to post Share on other sites
Pullstart 68,872 #233 Posted November 28, 2019 EB the brake and clutch rods are just 3/8” stock. You could easily get a 3/8-16 die and thread a cut end for a threaded rod coupling. Use of two rods cut in different spots may be just the ticket! 1 1 Share this post Link to post Share on other sites
ebinmaine 77,322 #234 Posted November 28, 2019 2 minutes ago, pullstart said: EB the brake and clutch rods are just 3/8” stock. You could easily get a 3/8-16 die and thread a cut end for a threaded rod coupling. Use of two rods cut in different spots may be just the ticket! Ahh Yes!! I have a set of taps and dies.... Share this post Link to post Share on other sites
Lee1977 7,551 #235 Posted November 28, 2019 (edited) 8 hours ago, pullstart said: More detail on that exhaust please? That is 2" tail tipe tubing with nothing in it. The runners up are electrical tubing . The muzzel brake is a 2 1/2" washer with a 1" hole and two 2" washers with a 3/4" hole space apart with drilled out 1/4" nuts. It stopped the high pearsing sound. It's not quite or too loud. It's on a 18HP Briggs Vanguard. I forgot the pictures, got busy with something else. Edited November 29, 2019 by Lee1977 3 Share this post Link to post Share on other sites
Pullstart 68,872 #236 Posted December 5, 2019 You were supposed to have 4 days to bring us updates, weren’t you EB? 3 Share this post Link to post Share on other sites
ebinmaine 77,322 #237 Posted December 5, 2019 8 minutes ago, pullstart said: You were supposed to have 4 days to bring us updates, weren’t you EB? Is it okay if I blame Trina because she was too busy to work on my tractor? 1 Share this post Link to post Share on other sites
Pullstart 68,872 #238 Posted December 5, 2019 No, she was busting butt to keep you warm! 1 1 Share this post Link to post Share on other sites
ebinmaine 77,322 #239 Posted December 5, 2019 3 minutes ago, pullstart said: No, she was busting butt to keep you warm! Quite true. Quite true. in sort of a sideways manner I did get a couple things done. Just organization and piling stuff. Share this post Link to post Share on other sites
Pullstart 68,872 #240 Posted December 5, 2019 Well, we can let that slide. Just don’t let it happen again next time you have 4 days off 1 Share this post Link to post Share on other sites
ebinmaine 77,322 #241 Posted December 8, 2019 Well folks, I was finally able to get the paint department freed up for a few minutes to begin some cleaning up and throwing a little paint at this project. Trina was grinding off the surfaces of a couple of plow blades which I'll post in another section.... so while she had all the stuff out and gear on, she did some wire brushing on the frame that we're going to use. Before: After today's work: Still a ways to go but we ran out of time and daylight. A few days ago I picked up several different colors that I wanted her to trial spray to see how I liked them for different parts of the tractor. I was originally going to go with a hammered bronze for the frame, adapter, transmission... But as it turns out that color is much more plain steel colored than I was looking for. I'll very likely use that for other parts of the tractor but not the whole lower carriage. While I was at the store I also picked up a hammered brown color and a metallic brown color which has a very interesting sand texture after being sprayed. The hammered brown and metallic brown are pictured below, painted on the trans to frame adapter. Hammered: Metallic Brown: Look at the sparkles from the metal flake in this stuff. Imagine the whole front suspension, frame, adapter, transmission... All covered in this color. 5 Share this post Link to post Share on other sites
Stormin 9,987 #242 Posted December 8, 2019 23 minutes ago, ebinmaine said: front suspension A tractor with suspension? Share this post Link to post Share on other sites
ebinmaine 77,322 #243 Posted December 8, 2019 22 minutes ago, Stormin said: A tractor with suspension? Well no... Just the standard Horse pivoting beam... I did think seriously about it on this build but I just don't need anything other than the stock set-up. Share this post Link to post Share on other sites
WHNJ701 4,169 #244 Posted December 8, 2019 I gave up wire wheeling parts, get a plastic tote, and 10 gallons of cheap white vinegar, soak it for a week 1 Share this post Link to post Share on other sites
Pullstart 68,872 #245 Posted December 8, 2019 That metallic brown reminds me of an 80’s speedboat of your choice. Good to see some progress you two! 2 Share this post Link to post Share on other sites
WHNJ701 4,169 #246 Posted December 8, 2019 12 minutes ago, pullstart said: That metallic brown reminds me of an 80’s speedboat of your choice. Good to see some progress you two! almost the same color as a brillion garden tractor. 1 Share this post Link to post Share on other sites
ebinmaine 77,322 #247 Posted December 8, 2019 4 minutes ago, jabelman said: almost the same color as a brillion garden tractor. I ((think)) what we have is slightly darker. But ... I've never seen a Brillion in person. Nice color though. I'd still use it if it were the same. 25 minutes ago, jabelman said: I gave up wire wheeling parts, get a plastic tote, and 10 gallons of cheap white vinegar, soak it for a week I'll run it by the paint department. We've talked about making up an electrolysis tub too. She really likes the hands on physical activity of building these rigs. 2 1 Share this post Link to post Share on other sites
pfrederi 19,874 #248 Posted December 9, 2019 For frames and heavy metal that is rusted needle scaler 2 Share this post Link to post Share on other sites
MikMacMike 494 #249 Posted December 9, 2019 9 hours ago, ebinmaine said: I ((think)) what we have is slightly darker. But ... I've never seen a Brillion in person. Nice color though. I'd still use it if it were the same. I'll run it by the paint department. We've talked about making up an electrolysis tub too. She really likes the hands on physical activity of building these rigs. And do the electrolisis setups work, Ive made a small temporary one in the past to remove a yoke in a ford aerostar transfer case, I tried everything and nope it was stuck solid, so i did the electrolisis thingy with baking soda, my word it came out black but i tapped it and whoosh out came the yoke, saved my but. id love to have a big tub setup for sure. 1 Share this post Link to post Share on other sites
Lee1977 7,551 #250 Posted December 19, 2019 Eric what have you been doing on this project? We want to see some progress. You have been at this for 3 1/2 months all we've seen is the frame and the extension block.and I think a couple of tires. Not even sure you ordered the tires it's been so long. Richie started a new project a week ago and already has a rolling chases. Ready to mount the engine. 1 1 4 Share this post Link to post Share on other sites
