Pullstart 68,521 #76 Posted November 3, 2019 That’s a pretty sweet creation you’ve made! 1 Share this post Link to post Share on other sites
PeacemakerJack 10,837 #77 Posted November 3, 2019 That is a mean looking machine for sure! Maybe I missed it somewhere in the above text. How much weight does that chain add to your tractor? 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,818 #78 Posted November 3, 2019 1 hour ago, PeacemakerJack said: That is a mean looking machine for sure! Maybe I missed it somewhere in the above text. How much weight does that chain add to your tractor? Thx! About 20’ total length of chain. Approximately 200 lbs. total... 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,818 #79 Posted December 18, 2019 My son is back from University of Utah for the Christmas break. Decided to cruise the hood with the old man on the WHrat WHrecker... I of course drove the sensible C105... Good times at 19 degrees...!!! Typical kid... texting and driving...!!! 86849241-D5C5-4E24-9EEF-371B698EB8AF.MOV B8889A66-0559-4780-9E33-B3A471BB918B.MOV 1 2 2 Share this post Link to post Share on other sites
Pullstart 68,521 #80 Posted March 21, 2020 Hey Jim! I’m gonna post it here because your PVC dually adapters reminded me of something when I watched the video... anybody think this idea between two wheels with a bucket for a ring and some 1/2” threaded rod would be able to produce a cement filled dually adapter? I think in the video or the comments, someone mentioned a bladeless sawzall to keep settling the concrete inside a bag. 1 2 Share this post Link to post Share on other sites
SylvanLakeWH 29,818 #81 Posted March 21, 2020 20 minutes ago, pullstart said: Hey Jim! I’m gonna post it here because your PVC dually adapters reminded me of something when I watched the video... anybody think this idea between two wheels with a bucket for a ring and some 1/2” threaded rod would be able to produce a cement filled dually adapter? I think in the video or the comments, someone mentioned a bladeless sawzall to keep settling the concrete inside a bag. Love it! Great video @pullstart! Yes - I think it would work just fine for dually spacers. Would need to create a bottom to pour the cement onto and keep even with the spacer. Then account for the bolts (I like his approach, but would add length). Not sure I would want any more weight on the outside rim though - I'm running very little pressure to keep the strain off the seals. So far so good! I'd keep the weight to the inside - so from the spacer in... I will probably not be trying this, as the WHrat WHrecker is just for fun and spinning them, along with wheelies, is a big part of that... Don't want to much traction on this filly...!!! Thanks for the great addition to the thread! If anyone does this please post! 1 Share this post Link to post Share on other sites
Pullstart 68,521 #82 Posted March 23, 2020 On 3/21/2020 at 5:41 PM, SylvanLakeWH said: Love it! Great video @pullstart! Yes - I think it would work just fine for dually spacers. Would need to create a bottom to pour the cement onto and keep even with the spacer. Then account for the bolts (I like his approach, but would add length). Not sure I would want any more weight on the outside rim though - I'm running very little pressure to keep the strain off the seals. So far so good! I'd keep the weight to the inside - so from the spacer in... I will probably not be trying this, as the WHrat WHrecker is just for fun and spinning them, along with wheelies, is a big part of that... Don't want to much traction on this filly...!!! Thanks for the great addition to the thread! If anyone does this please post! The reason I was thinking of this, is I am planning on picking up a FEL soon. The rear tires I’d like to be very wide for the most stability... understanding that the weight should be planted on the inside tires mainly. I’d offset that by using more pressure on the inside tires and just keep the others inflated to stay beaded. Another option would be to use super wide 26” tires and move the fender and floorboards as needed. 1 Share this post Link to post Share on other sites
ebinmaine 75,747 #83 Posted March 23, 2020 5 minutes ago, pullstart said: The reason I was thinking of this, is I am planning on picking up a FEL soon. The rear tires I’d like to be very wide for the most stability... understanding that the weight should be planted on the inside tires mainly. I’d offset that by using more pressure on the inside tires and just keep the others inflated to stay beaded. Another option would be to use super wide 26” tires and move the fender and floorboards as needed. Kind of mulling over in my head if dual tires would be any more stable than wide tires. Keeping in mind that the outside tires, as you stated, need to have much less air pressure I'm not sure how much ground pressure they would be able to give you in comparison to a single super wide tire which can be fully inflated and liquid-filled of course. If you were to run dual 8.5 or 10.5 wide tires you could liquid fill all 4. Keep the outside set a gallon low maybe? To allow for extra slosh and expansion. Run the inside tires at full pressure around 8 PSI. Outside set more like 3 or 4 PSI. That would at least, give you all that extra weight of 5 or 6 gallons of fluid for tire in the outside set. Share this post Link to post Share on other sites
Pullstart 68,521 #84 Posted March 23, 2020 10 minutes ago, ebinmaine said: Kind of mulling over in my head if dual tires would be any more stable than wide tires. Keeping in mind that the outside tires, as you stated, need to have much less air pressure I'm not sure how much ground pressure they would be able to give you in comparison to a single super wide tire which can be fully inflated and liquid-filled of course. If you were to run dual 8.5 or 10.5 wide tires you could liquid fill all 4. Keep the outside set a gallon low maybe? To allow for extra slosh and expansion. Run the inside tires at full pressure around 8 PSI. Outside set more like 3 or 4 PSI. That would at least, give you all that extra weight of 5 or 6 gallons of fluid for tire in the outside set. The rear tires on my buddy’s 312-8 are mine and tubed / fluid filled. There is zero air pressure, just the outward force of the fluid inside. If I were to do the same with a dually setup, 8 could add 5-8 lbs or air to the inside and leave the outer sat zero rate. Of of course I haven’t even seen the tractor but will later today. Maybe it has cement filled dually adapters and two sets of fluid filled 26x14’s! 1 1 Share this post Link to post Share on other sites
Bigtrx34 321 #85 Posted March 23, 2020 Missed this one when you started it. Glad to someone in the area saved this one. Doing a great job on the build 1 1 Share this post Link to post Share on other sites
Pullstart 68,521 #86 Posted March 23, 2020 15 minutes ago, Bigtrx34 said: great job on the build 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,818 #87 Posted May 13, 2020 Just an addendum to the build. Front hitch. Specifically "Designed" to match the overall aesthetics of the tractor, with particular attention to the aerodynamic lines... Only criteria - needed to be sourced from my garage, with no expense and certainly no violation of the Governor's Stay Home Stay Safe order... A couple of the bolts even match... 1 1 Share this post Link to post Share on other sites
ebinmaine 75,747 #88 Posted May 13, 2020 5 hours ago, SylvanLakeWH said: couple of the bolts even match. Careful there... Someone could accuse you of maybe being a neat freak or something.... 'round our yahd ( @pullstart that's Maine speak for "the land we live on") we prefer the older machines... But I love the super rugged look of the 'rat. 2 Share this post Link to post Share on other sites
Pullstart 68,521 #89 Posted May 13, 2020 Looks good Jim! Matching bolts... even a blind squirrel finds a nut sometimes! EB, even if you typed Pahk thah cah I’d know you were talking about something. Don’t you worry about me! 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,818 #90 Posted May 13, 2020 Well... Field testing complete - works like a charm! Nice to be able to move our 1972 boat around without the car, cranking my neck etc...!!! 1 5 Share this post Link to post Share on other sites
Tractorhead 9,215 #91 Posted May 13, 2020 Nice solution and nice Boat too 👍 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,818 #92 Posted May 17, 2020 (edited) Another addendum... Added a winch to the back. Had this thing in the box for couple of years - now it has a home. Powered it with a dedicated battery. No charger though, so will keep on a tender... Will be adding one more tow piece to her soon... Oh...Lost the dually's in order to fit everything in the garage for the summer... Edited May 17, 2020 by SylvanLakeWH 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,818 #93 Posted May 27, 2020 Should be the final post. Just added rear hitch to my WHrat WHrecker today... It is now my dedicated tow / tug now with front / back hitches and a winch. It is a light duty hitch and the receiver is a bit loose when pinned in, but for what I wanted it fits the bill. I used a couple metal shims and it is now snug as can be... For what I will be hauling around this is more than adequate... Its been a fun build... now just for cruising, pushing and pulling... 2 1 Share this post Link to post Share on other sites
Pullstart 68,521 #94 Posted October 17, 2020 I smell a WHRat in the stables... what shall we do? Thanks for the delivery and short visit Jim, it was great to meet you and yours! 2 2 Share this post Link to post Share on other sites
ebinmaine 75,747 #95 Posted October 17, 2020 Well lookitt there!!! 1 1 Share this post Link to post Share on other sites
Pullstart 68,521 #96 Posted October 17, 2020 6 minutes ago, ebinmaine said: Well lookitt there!!! Where? 2 Share this post Link to post Share on other sites
SylvanLakeWH 29,818 #97 Posted October 18, 2020 (edited) All I can say is: Edited October 18, 2020 by SylvanLakeWH 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,818 #98 Posted October 18, 2020 5 hours ago, pullstart said: Thanks for the delivery and short visit Jim, it was great to meet you and yours! Likewise Kevin! Sorry we were a bit late... Oh... Let me know if you need more chain! 3 Share this post Link to post Share on other sites
Pullstart 68,521 #99 Posted March 9, 2021 I mentioned the other day after a trail ride with Rylee that the front end is a bit wonky. The front tach-a-matic serves as a double shear for the front axle. I figure if she has so much fun riding the WHRat, I should make it safe! Trail Ride Fun: The front end: This parts front end will get a little sliced up to fit inside the frame extensions and bolted (or welded) into place. 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,818 #100 Posted March 9, 2021 Sounds like a good plan! Glad to see the WHrat WHrecker out and about and bringing smiles..! 1 Share this post Link to post Share on other sites
