Burnerman 759 #1 Posted August 27, 2019 Anyone make up their own plow angle handle? My son is making one based on my factory handle. It works and is bulletproof, but can it be made better? 1 Share this post Link to post Share on other sites
daveoman1966 3,881 #2 Posted August 27, 2019 For the BLACK rubber handle, use the round rubber handle from the implement lift lever. Just squeeze it a little bit flat and it'll slide onto the flat pre-fab lever handle your son made. 3 Share this post Link to post Share on other sites
Burnerman 759 #3 Posted August 27, 2019 3 minutes ago, daveoman1966 said: For the BLACK rubber handle, use the round rubber handle from the implement lift lever. Just squeeze it a little bit flat and it'll slide onto the flat pre-fab lever handle your son made. It may get a motorcycle hand grip. 😲 Share this post Link to post Share on other sites
gsummers 236 #4 Posted August 27, 2019 I also needed one made. I have a steel fabricating shop near me, they made an exact duplicate for $25 1 1 Share this post Link to post Share on other sites
ebinmaine 75,777 #5 Posted August 28, 2019 Good ideas. Share this post Link to post Share on other sites
Stepney 2,356 #6 Posted August 28, 2019 Yes, the originals are a little flimsy to say the least. I made mine out of heavy plate, and bent it more like the 260 series. Hangs out but goes right around the footplate. Share this post Link to post Share on other sites
Burnerman 759 #7 Posted August 28, 2019 6 hours ago, Stepney said: Yes, the originals are a little flimsy to say the least. I made mine out of heavy plate, and bent it more like the 260 series. Hangs out but goes right around the footplate. Do you have a picture of it? 1 Share this post Link to post Share on other sites
ebinmaine 75,777 #8 Posted August 28, 2019 3 minutes ago, Burnerman said: Do you have a picture of it? If it offers more foot room I'd use one. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #9 Posted August 28, 2019 1 hour ago, ebinmaine said: If it offers more foot room I'd use one. 260 series... 2 Share this post Link to post Share on other sites
ebinmaine 75,777 #10 Posted August 28, 2019 1 hour ago, WVHillbilly520H said: 260 series... So I take it that goes around the outside edge of the forward end of the step plate. Share this post Link to post Share on other sites
daveoman1966 3,881 #11 Posted August 28, 2019 18 minutes ago, ebinmaine said: So I take it that goes around the outside edge of the forward end of the step plate. Don't shape you index lever like this one for the 260 tractor. Make it like the one in the FIRST PICTURE in this string. That 1st pics is whats needed for the B C tractors. Share this post Link to post Share on other sites
ebinmaine 75,777 #12 Posted August 28, 2019 42 minutes ago, daveoman1966 said: Don't shape you index lever like this one for the 260 tractor. Make it like the one in the FIRST PICTURE in this string. That 1st pics is whats needed for the B C tractors. Oh yeah. I know. Thanks Dave. Patriot is a B series and cinnamon is a C Series. I have two different snow plows here and on both of them that lever it's the step. 1 more so than the other. It's obvious to me that one of them was badly bent when I got it and I've tried to reconfigure it with limited success. That's why I was wondering about the 260 series lever. I wondered if I could get the entire lever to the outside edge of the foot step. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #13 Posted August 28, 2019 3 hours ago, ebinmaine said: So I take it that goes around the outside edge of the forward end of the step plate. I converted that blade over to fit B,C,3 &400 series and I do believe the lever set forward and to the side of the foot rest. The xi series had a better design in my opinion. 1 Share this post Link to post Share on other sites
Stepney 2,356 #14 Posted August 28, 2019 (edited) 8 hours ago, ebinmaine said: So I take it that goes around the outside edge of the forward end of the step plate. Correct. It's not 'accurate' but I find it more comfortable to use. And on the Electro my C style lever would hit the footplate. Also smack in the way of my foot. With the lever around the outside of the footplate, I have more room and a further reach which works well for me. I'll have to try and find an old photo of the Charger when i used to use it. Edited August 28, 2019 by Stepney 1 Share this post Link to post Share on other sites
Bean701 35 #15 Posted August 29, 2019 I got a blade in the deal with my 312. But this handle is missing. Anyone sell these custom ones? Share this post Link to post Share on other sites
Burnerman 759 #16 Posted August 29, 2019 22 hours ago, Bean701 said: I got a blade in the deal with my 312. But this handle is missing. Anyone sell these custom ones? Look in the classifieds and fleabay They run are $50. They really aren’t hard to make. I Imagine someone could draw up a build sheet if there’s not one on here already. I did some fitting of my stock one today and got all the slop out. it’s about the best way to do it. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #17 Posted August 30, 2019 On 8/28/2019 at 10:55 AM, WVHillbilly520H said: I converted that blade over to fit B,C,3 &400 series and I do believe the lever set forward and to the side of the foot rest. The xi series had a better design in my opinion. @ebinmaine... Found a couple more 260 series pics. Last one xi series 1 Share this post Link to post Share on other sites
ebinmaine 75,777 #18 Posted August 30, 2019 I reeeeelly like how that goes to the far outside of the area so it doesn't interfere with the brake pedal. Extra reach isn't an issue with my ape arms. I may have to experiment with that..... 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #19 Posted August 30, 2019 (edited) 2 hours ago, ebinmaine said: I reeeeelly like how that goes to the far outside of the area so it doesn't interfere with the brake pedal. Extra reach isn't an issue with my ape arms. I may have to experiment with that..... Toro still has that index lever available... "92-7036" for around $50 from whole assembly 79252 Edited August 30, 2019 by WVHillbilly520H 1 Share this post Link to post Share on other sites
pfrederi 19,276 #20 Posted August 30, 2019 The bent out version must use a cable instead of a rod does the routing of the cable through screw eyes around the bends make it harder to squeeze the release handle??? Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #21 Posted August 30, 2019 (edited) 1 hour ago, pfrederi said: The bent out version must use a cable instead of a rod does the routing of the cable through screw eyes around the bends make it harder to squeeze the release handle??? Yes it uses a cable (wire rope) and NO not anymore effort to squeeze the handle... https://www.toro.com/en/parts/partdetails?id=18799 Edited August 30, 2019 by WVHillbilly520H 1 Share this post Link to post Share on other sites
