AHS 1,594 #1 Posted August 20, 2019 This started in ‘12 or ‘13.. it’s been a long time!! Ahh well!!👍 it was green paint with yellow wheels!!, and I could NOT stand a wheel horse to look like that. It was started by the key switch, (no selenoid).. and I re wired the whole thing. This year, I have bought things off eBay.. selenoid, key switch and carb rebuild kit. And stuff I have not found... which is the choke bracket!! Here’s the pictures I have so far. 6 Share this post Link to post Share on other sites
ebinmaine 77,345 #2 Posted August 20, 2019 Looks good so far. I have a couple of 12 horse engine in the shed. Maybe I have a choke bracket... You should definitely get a screen on that flywheel as well. I'll be looking forward to seeing your progress... 2 Share this post Link to post Share on other sites
Stepney 2,357 #3 Posted August 20, 2019 The choke bracket is little more then a bent piece of sheet metal, in the worse case. I might have one up in my shed, too. I'll have a peek around. Do you have the air filter housing? Share this post Link to post Share on other sites
AHS 1,594 #4 Posted August 20, 2019 21 minutes ago, Stepney said: The choke bracket is little more then a bent piece of sheet metal, in the worse case. I might have one up in my shed, too. I'll have a peek around. Do you have the air filter housing? Yup! Share this post Link to post Share on other sites
AHS 1,594 #5 Posted August 21, 2019 1 hour ago, ebinmaine said: Looks good so far. I have a couple of 12 horse engine in the shed. Maybe I have a choke bracket... You should definitely get a screen on that flywheel as well. I'll be looking forward to seeing your progress... The choke bracket, it looks like, the bracket goes off the coil. Right between the carb and the coil.... oh ya... and especially with two youngsters running around, ill get a screen on that flywheel!👍 1 Share this post Link to post Share on other sites
ebinmaine 77,345 #6 Posted August 21, 2019 37 minutes ago, AHS said: screen You have one? Share this post Link to post Share on other sites
AHS 1,594 #7 Posted August 21, 2019 9 hours ago, ebinmaine said: You have one? No Share this post Link to post Share on other sites
ebinmaine 77,345 #8 Posted August 21, 2019 4 minutes ago, AHS said: No I'll take a look and see if I have a spare one. Yours for the freight cost if you want it unless you want to drive down for a visit... Or go to the meet and greet in Berwick Share this post Link to post Share on other sites
AHS 1,594 #9 Posted August 21, 2019 12 hours ago, ebinmaine said: I'll take a look and see if I have a spare one. Yours for the freight cost if you want it unless you want to drive down for a visit... Or go to the meet and greet in Berwick Haha!! Nope! I’m way up by Bangor! I want tracking info! My zip code is 04428. How do you want to be paid? Venmo or PayPal? Share this post Link to post Share on other sites
ebinmaine 77,345 #10 Posted August 21, 2019 8 minutes ago, AHS said: Haha!! Nope! I’m way up by Bangor! I want tracking info! My zip code is 04428. How do you want to be paid? Venmo or PayPal? PayPal works fine. Let me make sure I have one here and I'll get back to you. Share this post Link to post Share on other sites
ebinmaine 77,345 #11 Posted August 22, 2019 @AHS I guess I can't really help you out after all. The one I knew I had down there is for a much smaller Tecumseh and not the 12-horse Kohler that I thought. Give Lincoln at A to Z tractor a call..... Share this post Link to post Share on other sites
AHS 1,594 #12 Posted August 22, 2019 53 minutes ago, ebinmaine said: @AHS I guess I can't really help you out after all. The one I knew I had down there is for a much smaller Tecumseh and not the 12-horse Kohler that I thought. Give Lincoln at A to Z tractor a call..... Ok Share this post Link to post Share on other sites
AHS 1,594 #13 Posted August 23, 2019 The first picture I had posted, of key switch. I’m thinking completely insulated yellow female post ends. Because what if, sometime when I’m riding along, the wires will touch each other.... what have you done with your key switch? Share this post Link to post Share on other sites
ebinmaine 77,345 #14 Posted August 23, 2019 I can take a couple pictures for you later today if you like. On one or two of ours are used a replacement 5 pin connector so as to keep the wire terminals insulated from the gas tank. All of our gas tanks are metal so obviously I would rather not have them get into any arguments with bare terminals. In your case, you can take those five wires and tie them together fairly close to the switch with a zip tie. I've done that as well. I have also used slightly oversized heat shrink tubing which will go over the end of the terminal and also over the yellow connector itself. Then shrink it down in place so it forms a good insulator. Share this post Link to post Share on other sites
AHS 1,594 #15 Posted August 23, 2019 30 minutes ago, ebinmaine said: I can take a couple pictures for you later today if you like. On one or two of ours are used a replacement 5 pin connector so as to keep the wire terminals insulated from the gas tank. All of our gas tanks are metal so obviously I would rather not have them get into any arguments with bare terminals. In your case, you can take those five wires and tie them together fairly close to the switch with a zip tie. I've done that as well. I have also used slightly oversized heat shrink tubing which will go over the end of the terminal and also over the yellow connector itself. Then shrink it down in place so it forms a good insulator. Ya, I have seen the 5 pin replacement connector.... that’s just another thing I will have to buy!🙁 oh well! Share this post Link to post Share on other sites
ebinmaine 77,345 #16 Posted August 23, 2019 3 minutes ago, AHS said: Ya, I have seen the 5 pin replacement connector.... that’s just another thing I will have to buy!🙁 oh well! Those are not a big expense. $9 or $10 off of the popular auction site. I got a link from Richard, @953 nut 1 Share this post Link to post Share on other sites
AHS 1,594 #17 Posted August 24, 2019 Got the carb and the coil on today. Wanted to see if it was getting fire...turned the key an no starter... jumped the selenoid and it has fire! 1 Share this post Link to post Share on other sites
ebinmaine 77,345 #18 Posted August 24, 2019 Time for a starter rebuild? Share this post Link to post Share on other sites
AHS 1,594 #19 Posted August 25, 2019 No, I jumped it, and the starter spun. I’m gonna take the S lead off the ignition switch and touch the positive on the battery... that otta make the starter spin! 1 Share this post Link to post Share on other sites
953 nut 64,125 #20 Posted August 25, 2019 Is that shiny new solenoid grounded properly? Share this post Link to post Share on other sites
AHS 1,594 #21 Posted August 25, 2019 32 minutes ago, 953 nut said: Is that shiny new solenoid grounded properly? Ok! Those two male prongs.. even if there at the same point continuity wise? I mean I have put a meter on the two of these, and there at the same point. One goes to ground (-) and one goes to S (+)? Won’t that break a fuse? I know what you mean. Share this post Link to post Share on other sites
AHS 1,594 #22 Posted August 25, 2019 Well I guess the tractor doesn’t work now. I will ground the other terminal and see what happens!😄 1 Share this post Link to post Share on other sites
AHS 1,594 #23 Posted August 26, 2019 I guess you were right! 953 nut! Hooked the ground up and it turned over!👍 here’s a picture of the Raider 12, and my celebratory beer, slowly getting back together! I will get all of the wires net and out of the way. The 5 pin connector, that hooks to the key switch, I heard you have them @953 nut. Can you send me a picture? 1 Share this post Link to post Share on other sites
ebinmaine 77,345 #24 Posted August 26, 2019 He's the one that gave me the link to fleabay... Here's the item number you can search for on there: 122756068206 1 Share this post Link to post Share on other sites
AHS 1,594 #25 Posted August 26, 2019 14 hours ago, ebinmaine said: He's the one that gave me the link to fleabay... Here's the item number you can search for on there: 122756068206 Ordered it! All set with the wonky, non insulated female clip idea! A rubber connector would be much appreciated! Now I can get the choke cable piece... I think I’m going to have to make it... 1 Share this post Link to post Share on other sites
