Clarence T. Nolley Jr 14 #1 Posted August 20, 2019 hello again guy's Clarence here,wanted to know if the C160 can be fitted with an engine mount, it now has the kohler 16hp engine, if so let me know i am planning on using a mount this time because i don't like the way my engine fit on my frame. please help me with this Thanks. Share this post Link to post Share on other sites
Racinbob 13,286 #2 Posted August 20, 2019 Confused here. What is it that you don't like? Share this post Link to post Share on other sites
pfrederi 21,312 #3 Posted August 20, 2019 19 minutes ago, Racinbob said: Confused here. What is it that you don't like? Share this post Link to post Share on other sites
pacer 3,181 #4 Posted August 20, 2019 Do you maybe have whats referred to as a 'shaker mount' with the engine mounted in rubber cushions?? The rubber in these are prone to rot after these many years.... Share this post Link to post Share on other sites
ebinmaine 81,153 #5 Posted August 20, 2019 1 hour ago, pacer said: Do you maybe have whats referred to as a 'shaker mount' with the engine mounted in rubber cushions?? The rubber in these are prone to rot after these many years.... Shouldn't have a shaker mount on a c-160. Direct bolt engine to frame. 1 Share this post Link to post Share on other sites
WHX?? 58,347 #6 Posted August 20, 2019 Bit confused here too Clarence. Are you trying to do a repower? Share this post Link to post Share on other sites
oliver2-44 11,825 #7 Posted August 20, 2019 If it's the way the block hangs over the frame and appears to have two unused bolt holes. Those oil pans have 2 bolt that thread from the bottom of the frame up into threaded holes in the oil pan on that side. Very solid mount, but confusing if you don't realize those bolts are on the bottom side. 4 Share this post Link to post Share on other sites
Ed Kennell 47,825 #8 Posted August 20, 2019 3 hours ago, Clarence T. Nolley Jr said: C160 can be fitted with an engine mount Can you post a picture of this engine mount that you plan to use? to the Share this post Link to post Share on other sites
Clarence T. Nolley Jr 14 #9 Posted August 20, 2019 Oliver 2-44 that sounds like what i have , thanks man i took pictures before disassembly but did not like the way it mounted to my frame. Share this post Link to post Share on other sites
Clarence T. Nolley Jr 14 #10 Posted July 23, 2020 (edited) hello guy's i am back,i have been real busy with my Horse trying to reassemble everything back she is looking good. i have the wiring harness out of her now thinking of rewiring the complete unit with new wiring, i may need some assistance so i will be bringing you up to date with my progress.and send some pic's too. Edited July 23, 2020 by Clarence T. Nolley Jr 1 Share this post Link to post Share on other sites
ebinmaine 81,153 #11 Posted July 23, 2020 Clarence there's some great info here: Share this post Link to post Share on other sites
