Steph 5 #1 Posted August 19, 2019 (edited) My husband and I recently purchased a Wheelhorse to restore. But, upon getting the tractor home and doing some more research we are unsure if the model stick on the tractor is correct. Unfortunately, the serial number plate is MIA. The stick on the tractor says 605, but it has an electic start. How can we determine what the exact model of the tractor is? We did get the unit running (with my husband's ingenuity) since we are looking for a fuel pump. Any input is greatly appreciated. Thank you in advance!!!! Edited August 20, 2019 by Steph Added pics 5 Share this post Link to post Share on other sites
bottjernat1 2,196 #2 Posted August 19, 2019 photos if you can upload will help out alot. but if it is a 605 here are some things to get you in the right direction. not everything is correct all the time on tractor data but it is the best place to get a general idea of what you have. but with photos these folks are the best place for your information you need. Here is the tractor data link for a 605! http://www.tractordata.com/lawn-tractors/000/3/1/314-wheel-horse-605.html 1 Share this post Link to post Share on other sites
ebinmaine 79,128 #3 Posted August 19, 2019 in your fuel pump want ad you mentioned you had a k181 so you have an 8 horse Kohler. Sounds like what you have there could be referred to as an 855. In nearly 55 years there's no telling what any number of previous owners would have done to your tractor. Maybe you have an original 855 with a changed belt guard and maybe it's the other way around. Either way you've got a great little piece of machinery and American history Please do take a moment to go into the Introduction Section and post a few pics of your tractor. We all LOVE pics. 2 Share this post Link to post Share on other sites
rjg854 13,078 #6 Posted August 20, 2019 I'm not sure if anyone has mentioned it, but 1 Share this post Link to post Share on other sites
Steph 5 #7 Posted August 20, 2019 Thank you!! I have added pics above. Share this post Link to post Share on other sites
953 nut 66,572 #8 Posted August 21, 2019 You have a 1965 model 605 according to the belt guard, but a 605 would have come with a Tecumseh 6 HP pull start engine. The engine may have been changed or the belt guard, who knows. There should be a model number plate under the dash board. Take a look to see if it is there. Share this post Link to post Share on other sites
AMC RULES 37,259 #9 Posted August 21, 2019 That's a rarely seen tractor... if it works out to be legit. 1 Share this post Link to post Share on other sites
CasualObserver 3,416 #10 Posted August 21, 2019 3 hours ago, AMC RULES said: That's a rarely seen tractor... I was thinking the same thing Craig. 1 Share this post Link to post Share on other sites
Pullstart 70,103 #11 Posted August 21, 2019 I have a couple Tecky powered tractors, they have provisions for pull OR electric start. Did the 60x models have no starter, or did the 65x models not originally come with a recoil too, or were there exceptions along the way no matter what? Share this post Link to post Share on other sites
ebinmaine 79,128 #12 Posted August 21, 2019 2 hours ago, pullstart said: I have a couple Tecky powered tractors, they have provisions for pull OR electric start. Did the 60x models have no starter, or did the 65x models not originally come with a recoil too, or were there exceptions along the way no matter what? Kevin I'm kind of under the impression that the 6 0 x was pull start only. The 6 5x was electric start but also had a recoil. Trina's 657 Tecumseh is a battery-operated electric start with a recoil s well. To the best of anyone's knowledge and by the Numbers matching, that should be original. Share this post Link to post Share on other sites
953 nut 66,572 #13 Posted August 21, 2019 605 and 655 left the factory with engines that had different spec numbers. I would presume the electric starter and charging system would be the reason. Share this post Link to post Share on other sites
Steph 5 #14 Posted August 22, 2019 I believe the engine information is: Kohler K181S Serial# B223001 Spec# 30108D Share this post Link to post Share on other sites
953 nut 66,572 #15 Posted August 22, 2019 That would be correct for the 1966 model 856. Share this post Link to post Share on other sites
