JBall 2 #1 Posted August 16, 2019 Found a donor K241 10 horse engine with a starter generator system for a fair deal. Will it fit in my 1980 c-85 wheel horse? My c-85 had a k181 in it with an electric starter. Will i need to change out any parts for the donor engine to work and the K241 is from a cub cadet. Share this post Link to post Share on other sites
Pullstart 71,516 #2 Posted August 16, 2019 I believe the 10 horse will bolt right up, as the 8 horse is on a riser plate. With a wiring swap, you should be smooth sailing on the swap. 2 Share this post Link to post Share on other sites
JBall 2 #3 Posted August 16, 2019 Pull start what is required on a starter generator system that’s different from a electric starter system. Share this post Link to post Share on other sites
953 nut 70,312 #4 Posted August 16, 2019 (edited) 10 hours ago, JBall said: the K241 is from a cub cadet The oil pan from the Cub won't have the bolt holes in the bottom to bolt to the frame on the PTO side, but that can be handled with a couple "J" Bolts. With the Cub Cadet counter clockwise Starter/Generator being on the PTO side of the engine you may have a problem aligning the drive belt for the transmission unless you put the clockwise S/G unit and pulley on like was used on nearly everything but the Cubs. If you replace your ignition switch with a # 103-990 switch and follow this basic wiring diagram you should be fine. Your safety switches are not included in the basic drawing, but need to be added. The generator light can be omitted and a volt meter attached to the Ignition Switch "A" terminal. Also, a 30 amp fuse should be added to the yellow wire from the voltage regulator to ignition switch "R" terminal and a 15 amp fuse prior to the light switch for safety. Lots of good information in this post. In post # 14 there is a good color coded layout with safety switches done by @BOB ELLISON for a "C" series. If you decide to do this swap please ask questions as you go along so we can help you have a successful swap. Edited August 16, 2019 by 953 nut 2 1 Share this post Link to post Share on other sites
Tuneup 1,459 #5 Posted August 16, 2019 Welcome! I grew-up in Morris County and lived in Warren County for a while. You're where it really is the Garden State. Good luck! 1 Share this post Link to post Share on other sites
clueless 3,440 #6 Posted August 16, 2019 (edited) If the 10 hp doesn't have the right oil pan it will not bolt up to your shaker engine mount. The C-85 has the isolator plate. If you can find a kohler 8 hp K or magnum they will fit the mount fine even a 7 or 6.25 hp kohler will fit. Edited August 16, 2019 by clueless Share this post Link to post Share on other sites
JBall 2 #7 Posted August 16, 2019 1 hour ago, clueless said: If the 10 hp doesn't have the right oil pan it will not bolt up to your shaker engine mount. The C-85 has the isolator plate. 5 hours ago, 953 nut said: The oil pan from the Cub won't have the bolt holes in the bottom to bolt to the frame on the PTO side, but that can be handled with a couple "J" Bolts. With the Cub Cadet counter clockwise Starter/Generator being on the PTO side of the engine you may have a problem aligning the drive belt for the transmission unless you put the clockwise S/G unit and pulley on like was used on nearly everything but the Cubs. If you replace your ignition switch with a # 103-990 switch and follow this basic wiring diagram you should be fine. Your safety switches are not included in the basic drawing, but need to be added. The generator light can be omitted and a volt meter attached to the Ignition Switch "A" terminal. Also, a 30 amp fuse should be added to the yellow wire from the voltage regulator to ignition switch "R" terminal and a 15 amp fuse prior to the light switch for safety. Lots of good information in this post. In post # 14 there is a good color coded layout with safety switches done by @BOB ELLISON for a "C" series. If you decide to do this swap please ask questions as you go along so we can help you have a successful swap. I’ll ask the guy that has the engine to send me pics 1 Share this post Link to post Share on other sites
JBall 2 #8 Posted August 16, 2019 6 hours ago, JBall said: I’ll ask the guy that has the engine to send me pics I want to go with the swap. I read the diagram and have a couple of questions. I can reuse the voltage regulator on my tractor correct? what you mean by generator light, my tractor only has a amp meter. If I get the engine with a cub cadet generator where can I find a oem wheel horse generator? Do you have pictures of what a K241 with a starter generator in a wheelhorse. Share this post Link to post Share on other sites
clueless 3,440 #9 Posted August 16, 2019 For the most part this is not going to be a simple swap. Share this post Link to post Share on other sites
953 nut 70,312 #10 Posted August 16, 2019 You can not use your voltage regulator because the CC K241 has no charging system. The early Wheel Horses had a light on the dash that would glow if the generator was not putting out more voltage than the battery. The Starter/Generator from most other brands that had a Kohler 10 or 12 HP engine will work for you. You can find them on or from used garden tractor suppliers. I would suggest you call Lincoln at A-Z Tractor, he is great. https://a-ztractor.com/. You will also want a belt guard for the S/G belt. Here is a picture of a K 241 with S/G. Share this post Link to post Share on other sites
