953 nut 69,578 #26 Posted August 11, 2019 No problem, none of us were born knowing this stuff, we learned it from others. Clockwise from the flywheel side. Share this post Link to post Share on other sites
1977walleyeguy 18 #27 Posted August 11, 2019 36 minutes ago, 953 nut said: No problem, none of us were born knowing this stuff, we learned it from others. Clockwise from the flywheel side. So true! my younger self might not agreed with that lol thanks for the verification. 1 Share this post Link to post Share on other sites
1977walleyeguy 18 #28 Posted August 11, 2019 Having fun C0E10270-4928-4736-939D-AC26BF1430B2.MOV 1 Share this post Link to post Share on other sites
Digger 66 3,530 #29 Posted August 11, 2019 On 8/7/2019 at 1:34 PM, 1977walleyeguy said: Do any of you have a particular brand or recommendation for a timing light to use when i get to the point that i am checking and possibly setting the points on this K241? Its not something i currently own and will add to the toolbox. I have an old Sun timing light that hasn't seen the light of day in probably 30 years . I bet it still works though . 1 Share this post Link to post Share on other sites
1977walleyeguy 18 #30 Posted August 14, 2019 On 8/8/2019 at 9:22 PM, 953 nut said: All Kohler K-241 engines built after 1965 were equipped with a compression release cam shaft that will slightly open the exhaust valve as it approached TDC on the compression stroke at low RPMs. As a result you will not get a good compression reading. A leak-down test is the best method of determining the engine's condition. https://mobiloil.com/en/article/car-maintenance/car-maintenance-archive/how-to-do-a-leakdown-test Update : 8-13-2019 I received my leak down test set yesterday and had a chance to test the cylinder tonight. bad news - I have air leaking thru the carb , which can only mean the intake valve isn’t right in some manor. while leaking down I rotated the flywheel full revs and the leak got less at some points and more when it should of been open. so it looks like I need to dig into the valves.... 1 Share this post Link to post Share on other sites
WHX?? 58,237 #31 Posted August 14, 2019 (edited) Might not be a big as deal as you think Walleye but does mean you should pull the head and check things out. Might be a a sticking valve or a piece of carbon holding the intake valve open or somthing like that.. Head gaskets are cheap yet so that's where I would be headed. Sides it is always wise sometime to just pull the head for drill and check the bore. Wouldn't hurt to pull the breather cover off and and have a peek in there at the springs/keepers either . Keep us posted. Edited August 14, 2019 by WHX24 2 Share this post Link to post Share on other sites
pfrederi 21,190 #32 Posted August 14, 2019 Also check the clearance between the valve stem and the tappet. (Behind the breather cover) The specification is in the service manual and in your engine they are adjustable. 1 Share this post Link to post Share on other sites
1977walleyeguy 18 #33 Posted August 14, 2019 Any recommendations for valve spring compression tool on this k241? Share this post Link to post Share on other sites
1977walleyeguy 18 #35 Posted August 14, 2019 here is the other option i came across which is better? 1 Share this post Link to post Share on other sites
WHX?? 58,237 #36 Posted August 14, 2019 This is the one I got Walleye.. kind of awkward to use but once you get the hang of it. Hobbyist quality too but beats two screwdrivers a load of French words. https://www.ebay.com/itm/8-Universal-Adjustable-Valve-Spring-Compressor-Automotive-Engine-Repair-Tool/231614807887?hash=item35ed517f4f:g:gDEAAOSws6dcU4MV 1 Share this post Link to post Share on other sites
1977walleyeguy 18 #37 Posted August 14, 2019 Update : 8-14-2019 pulled the head and breather - lots of carbon on the surfaces , but nothing scary. i can physically see that the intake valve isn’t seated all the way, but I can also see that the adjustment of the intake is higher (see breather photo) is higher than that of the exhaust valve. perhaps it worked up over time? bore doesn’t look bad for a 77 machine in my opinion but I’m a novice at this. Share this post Link to post Share on other sites
1977walleyeguy 18 #42 Posted August 14, 2019 Measurements : tappet to valves at TDC exhaust .020 clearance between intake .004 (.005 is snug) clearance between. Share this post Link to post Share on other sites
1977walleyeguy 18 #43 Posted August 14, 2019 Best method to decarbonize ? Share this post Link to post Share on other sites
