JoeM
36 inch RD Project Norelco
JoeM
Working in the R & D lab, I installed an extra set of blades on a 36 inch rear discharge deck.
How this idea started was the Horse Bug bit my brother. I gave him an old 211-4 cause one of his mowers was down. I must admit the 36 inch RD deck cut pretty nice. To small for me. He liked it so much he went on CL and bought a 208-4, cuts great too. Looking at those machines, the front of the deck is connected to the front axle and pivots with the from wheels. Sure seems like a nice design. (not to mention my brother is a nut about his lawn). I have been working on and off the last couple years on a 88 516H. Finally got it runnable and my brother came up and took her for a spin. (I think he is in love) but says he has no more room for another mower, but ask if there is a 36 inch rear deck that will fit.  :dunno: Well anyhow, I was working on a 36 just to have and thought if I put mulching blades on it to see if it competes. I seen a while back were a member used two sets of blades and thought that may give me that fine cut.
Some of my findings are; 1 makes more noise, 2 does use more power, 3 pulverizes the grass, super fine clippings, 4 does blow out from under the deck more, and 5 cuts pretty nice.
I had the height set a notch lower than usual and the cut pic it is hard to tell but don't look to bad.
I now some other members have done this and hope they share their thoughts.
297077531_36inchreardichargetopview.jpg.fc9d9f452cebb6bffdc0677d5064d64e.jpg1767464358_36inchreardichargebottomview.jpg.8660a7bfc53e445f3f27e1e9a0596ebd.jpg
631000540_36inchreardichargesideview1.jpg.ed01c6a21e007cc8d012c8666a2af359.jpg1474263683_36inchreardichargebottomclippings2view.jpg.f864d90bb31f59d51ec8978c1b3d1ebd.jpg
1741932446_36inchreardichargebottomclippings1view.jpg.e43af0cdba4c59ed5167070aae3d4a14.jpg1028894152_36inchrearcutview.jpg.f9494f9e8b58dc35370154661b9e2daa.jpg
  • Like 4
  • Similar Content
    • DaveQueener
      By DaveQueener
      I have my late father's 1965 Wheelhorse 10hp model 1045 with mower deck and dozer blade that I would like to get to a good home. My Dad was working on getting it running again shortly before he died. It's going to new new rear tires and the transmission seems to be stuck after sitting so long, but it does come with some extra gears for the manual transmission along with an extra housing.
      The 1045 did sell today to a friend in Knoxville for $475. He has an auto body shop and loves old equipemt, so I have every confidence it will get restored. My thanks to those of you who inquired. --Dave Q
    • PAguy
      By PAguy
      Hello gents!
      I find myself with a question for the forum before I go down the path of ripping my deck apart in the middle of the season.
      I have a 42 inch rear discharge 78350 that seems to have developed a crack at the center spindle (photo attached). At first I thought I had unbalanced blade issue bc the deck will vibrate something fearce. Long story short took it off got everything sharp and freshly greased. Started it up and it had the vibration again that reverberates through the deck. Now it's not as as bad as before but at the wrong angle or first starting it just vibrates loudly. So looked around and found the crack at the center spindle.
      Debating if a simple weld would be sufficient for this crack or it would need more extensive repair? I don't weld myself but before I bothered the guy that farms the property thought I would ask here for thoughts if someone has had this issue since I was not seeing something in the forum.
      Appreciate your guys help and thoughts.
    • MSBiker
      By MSBiker
      Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
      Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
    • Brockport Bill
      By Brockport Bill
      48" Mower Deck - Side Discharge model # 78361 -- # 312000163. This mower is listed as being manufactured at the near end of Wheel Horse production for this deck in 2012. This mower is in very good condition used only one season on small yard. Well cared for and stored indoors. The deck has double right side pulley for optional bagger attachment. Any owner who cares for this mower will have a great investment of a classic WH deck to last decades. Cash pick up Poughkeepsie, NY area. No returns. Please send p.m if interested
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
