woodbird007
Leaking Sunstrand
woodbird007
Very strong hydro on B100 automatic. Long story short, I fell off tractor, it ran against wall and keep working for several seconds before I was able shut it off. Now major hydro leak. Feedback on transmission prognosis and repairability please.  Btw, I suffered skinned knee and jammed shoulder. Lol
  • Sad 1
  • Heart 1
oliver2-44
Good to hear you only got minor injuries. Can you give us more details on where the leak is or some pictures
stevasaurus
More information would be great, but I will tell you the trans is fixable.  :occasion-xmas:
pfrederi
Sunstrand leaks if you do not have hydraulic lift are usually in the motion control it would run down the front of the transaxle and drip near the front. Whre is you rs dripping???
  • Similar Content
    • eo1bart
      By eo1bart
      Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
      Located in the New England area
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • Oily Charger 10
      By Oily Charger 10
      My Kohler Mystery engine has been making a knocking sound at low rpm. It sounds like this: do, do, do, do… do, do… do, do, do, do…
      here his a video all about.
      I would like some help. So far the camshaft is the thing making sound I think. I will be taking out the grenade gears…
    • giant_g2
      By giant_g2
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
