Pullstart 70,528 #26 Posted July 25, 2019 There’s quite a broad range of what does the job here, maybe we should mention how much grass needs trimming? I went with the zero turn because I actually felt like I just couldn’t keep up with the C-101 and the 42” RD. I mow somewhere around 3 - 3-1/2 acres. I could mow for 3-1/2 hours and not be satisfied with the appearance of the lawn. Now, I’m done in less than an hour. It might be a tad longer now, with 37 more trees than last year, but I can only imagine how much longer that would have taken with the tractor. I tried convincing my wife that we should let the front half of the yard grow between us and the road, but that was a loosing battle. 2 Share this post Link to post Share on other sites
bottjernat1 2,196 #27 Posted July 25, 2019 I mow my yard and my elderly neighbors with my youngest daughters 1969 charger automatic 12 hp kohler. It does a wonderful job! 1 Share this post Link to post Share on other sites
bds1984 1,513 #28 Posted July 25, 2019 The majority of the time I cut grass with my 315. It is a great machine, I just wish it would turn a little bit tighter. 4 Share this post Link to post Share on other sites
Racinbob 13,030 #29 Posted July 25, 2019 The majority gets done with the 05 Classic GT. I like to use the 76 B-160 for the paths. It won't surprise any of you but the fact that I'm running the 76 48" deck on the 05 Classic and the 42" from the 05 on the 76 has raised some eyebrows to the non Wheel Horse friends. 5 3 Share this post Link to post Share on other sites
Herder 2,356 #30 Posted July 25, 2019 Going home after work to cut some grass. Chop-chop. 9 2 3 Share this post Link to post Share on other sites
chip61 666 #32 Posted July 25, 2019 (edited) I cut 5-6 acres between my place and a couple neighbors lots with my 416 H with 48" deck down in Mathews Co. on the Bay. The grass is almost always tall and thick as we are just above sea level down there so unless we have drought conditions the grass never seems to get dry and slow down, The 314 mainly does trailer duty now, and I took the C160 with 42" deck back home to cut my grass and my son's grass. That's still my favorite machine to mow with. Edited July 25, 2019 by chip61 typo 4 1 Share this post Link to post Share on other sites
cafoose 3,754 #33 Posted July 25, 2019 I do most of my mowing with my 520HC and smaller areas with my new Husqvarna push mower with a Honda engine. 3 Share this post Link to post Share on other sites
adsm08 4,771 #34 Posted July 25, 2019 I was on my way home this afternoon and I saw a guy mowing on a Charger just up the street from me. 2 1 Share this post Link to post Share on other sites
SALTYWRIGHT 861 #35 Posted July 25, 2019 I use a toro 3225 z-turn. Share this post Link to post Share on other sites
AHS 1,694 #36 Posted July 25, 2019 On 7/24/2019 at 6:18 PM, Sparky said: Glad to see a couple of you using other brands ....I’m one of those guys as well. So probably 70% is done with my Craftsman with a 46” deck and a triple bagger setup and 30% is done with my WH C-105 with a 42SD. That’s my dad mowing my yard with the C-105 last year when I was laid up with a leg infection. Crapsmen!? Lol!!👍 2 Share this post Link to post Share on other sites
AHS 1,694 #37 Posted July 26, 2019 7 hours ago, Racinbob said: The majority gets done with the 05 Classic GT. I like to use the 76 B-160 for the paths. It won't surprise any of you but the fact that I'm running the 76 48" deck on the 05 Classic and the 42" from the 05 on the 76 has raised some eyebrows to the non Wheel Horse friends. So, I’m running a ‘00 42” RD on my ‘73 wheel horse. Share this post Link to post Share on other sites
gt14rider 1,233 #39 Posted July 26, 2019 I have been mowing with this , until I drove over sweeper with my plow truck, should be able to save it 1 Share this post Link to post Share on other sites
Herder 2,356 #40 Posted July 26, 2019 2 minutes ago, gt14rider said: I have been mowing with this , until I drove over sweeper with my plow truck, should be able to save it I hate when that happens. Dam plow trucks. 1 1 Share this post Link to post Share on other sites
skippy1969 135 #42 Posted August 28, 2019 I mow with my 1995 520H with a 42 inch sd deck. ][/url] Share this post Link to post Share on other sites
cleat 9,003 #43 Posted August 28, 2019 I am surprised you can run that 42" deck without the deck wheels hitting the rear tractor tires. I can only run 48 or 60 decks on my later model 520's Share this post Link to post Share on other sites
AHS 1,694 #44 Posted September 2, 2019 On 7/24/2019 at 3:06 PM, The Tool Crib said: This is what l use most of the time . 414-8. And this is what l use some of the time My 1067 How/ what did you do to attach the attach o mastic to your 1057? I’m talking about the mule drive! @The Tool Crib I have a 1970 Raider 12, and I can’t figure out how, without some extensive machining! Share this post Link to post Share on other sites
pfrederi 20,837 #45 Posted September 2, 2019 Two ways to do it for your raider. The correct front mule for that era pic 1 &2 or the adapter set Pic 3&4 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #46 Posted September 2, 2019 17 minutes ago, pfrederi said: Two ways to do it for your raider. The correct front mule for that era pic 1 &2 or the adapter set Pic 3&4 These are the exact two brackets I have on the front of my 1067. Then you can attach the meal drive to it . There's a left and a right bracket Share this post Link to post Share on other sites
AHS 1,694 #47 Posted September 2, 2019 2 hours ago, The Tool Crib said: These are the exact two brackets I have on the front of my 1067. Then you can attach the meal drive to it . There's a left and a right bracket Ok! Cool! Now are the brackets available on eBay? Or are they custom made? I have the 1 & 2 top bracket ( the early attach o matic!) Share this post Link to post Share on other sites
briankd 833 #48 Posted September 2, 2019 mowed with my 857 36 inch gear drive rear discharge deck for 10 yrs then restored it mowed another year and then retired it use it for sweeper duty and snow plow inherited 1970 JD 110 from father inlaw and it now my current mower does great job mowing but that all it does 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #49 Posted September 2, 2019 (edited) 28 minutes ago, AHS said: Ok! Cool! Now are the brackets available on eBay? Or are they custom made? I have the 1 & 2 top bracket ( the early attach o matic!) I'm not really sure on how to get these but somebody that has access to a metal shop can probably fabricate these pieces. It just so happened when I bought this tractor they were on it. I believe these brackets were an option for the older tractors to adapt to a newer deck . Edited September 2, 2019 by The Tool Crib Share this post Link to post Share on other sites
The Tuul Crib 7,354 #50 Posted September 2, 2019 4 minutes ago, briankd said: mowed with my 857 36 inch gear drive rear discharge deck for 10 yrs then restored it mowed another year and then retired it use it for sweeper duty and snow plow inherited 1970 JD 110 from father inlaw and it now my current mower does great job mowing but that all it does I have to say that that particular John Deere and the 112 were great machines. When these were built it was a time of quality. Such as Wheelhorse , Ford , John Deere , and a host of others ! 2 Share this post Link to post Share on other sites
