414-8 Gear Oil, Shift Boot and Low Range Questions
By
DDK319, in Transmissions and transaxles
Similar Content
By WheelPuke
I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
By nylyon-(Admin)
I think I am selling my 1987 414-8 with plow, weights and chains. Now here’s the story on this one. A long long time ago, I was searching for a snow plow for my 416H. In that search I stumbled onto a forum which was one day old. There was no name of the forum, just whtractor.15.forumer.com. Trying to learn more about snow plows I started conversations with one of the active members on the site, let’s call him Mike. Mike convinced me I didn’t need a plow, but an entirely new tractor.
About a week or so later, I found this 414–8 for sale, and bought it. I now had my plow and could plow the driveway. So what happened with Mike @Sparky and this forum I spoke of? It grew a little bit, and we now call it RedSquare, and for sale is one of if not THE reason RedSquare exists today, so you can own a piece of RedSquare history!
About the tractor: 1987 414-8. Kohler M14, runs well does not burn oil. Everything on the tractor works as it should, but it is a worker. The plow is a 48” with a custom made scraper blade, made from heavier stock than original. For the past several years, this has been a dedicated plow tractor, so it hasn’t seen a lot of work, but has also sat outside (under a tractor cover) so lots of let’s say, patina going on.
I a, selling because I just picked up a 416-8, and that will become my winter plow / blower tractor. I am looking for $550, but like I said this tractor is a bit of a legend!
I have cleaned it up since the pictures were taken.
By F. Marra 17
I have a late 80's 414-8. my transmission has a slow oil leak. it leaks slow so its hard to see where it is coming from. i get a small puddle/stain on the floor center under the trans after a few days of non-use. is there a usual problem area that leaks? or is there anyone in the NJ area that can be recommended to repair the trans? I am sure due to its age that gaskets or seals may be shot. the tractor sat for 10+ years at my office on a shelf. It has ran well the past 3 years for me. I would like to fix this leak if possible. Any advice or help is greatly appreciated.
THANK YOU,
Frank
