dmhill 43 #1 Posted July 20, 2019 My B-82 Briggs is surging, almost to the point of dying, at idle. Anyone have experience with this issue and could/would point me in the right direction. Share this post Link to post Share on other sites
wallfish 19,068 #2 Posted July 21, 2019 I'm not familiar with that particular engine but the most common cause of surging or governor hunting is the carburetor. It's either dirty or leaking in extra air. If you can smooth out the rpm by using the choke, that will indicate the carb is the problem . Probably time to pull off the carb and give it a thorough cleaning. 1 Share this post Link to post Share on other sites
dmhill 43 #3 Posted July 21, 2019 I will give it a good once through, thank you. Share this post Link to post Share on other sites
ohiofarmer 3,383 #4 Posted July 21, 2019 (edited) 18 hours ago, dmhill said: I will give it a good once through, thank you. Good explanation from my favorite youtuber [once you get past the antics that some ppl do not like] Not just what to do but why. These engines commonly lose adjustment due to people undoing the settings [like I did] by mistake when doing other repairs. https://www.smallenginerepairvideos.com/how-to-properly-set-the-governor-on-a-small-engine-with-taryl.html Edited July 21, 2019 by ohiofarmer Share this post Link to post Share on other sites
dmhill 43 #5 Posted July 21, 2019 Thank you! I will check it out. Share this post Link to post Share on other sites
