Jpbugeye 3 #1 Posted July 20, 2019 Hi guys, I recently got a 417a wheel horse that starts hard but runs well when started and runs poorly with the lights on and won't start after shutting off when it had been running..I am thinking the coil may be going , any other ideas? Jamie Share this post Link to post Share on other sites
pfrederi 20,535 #2 Posted July 20, 2019 Have you checked you voltage while running??? Adding headlights to the electrical load may drop your voltage enough to interfere with the spark. Before you buy a coil test it. Between the small + and - terminals on the coil you should read 4-5 ohms. Between the two high tension terminals 9500-11500 ohms Share this post Link to post Share on other sites
Jpbugeye 3 #3 Posted July 20, 2019 Thanks for the reply, I can test it soon..I thought the fact that it won't restart when coil is hot and hard starting when cold also suggested a weak spark. Share this post Link to post Share on other sites
pfrederi 20,535 #4 Posted July 20, 2019 38 minutes ago, Jpbugeye said: Thanks for the reply, I can test it soon..I thought the fact that it won't restart when coil is hot and hard starting when cold also suggested a weak spark. It may be a bad coil. Brace yourself if you have to buy a new one... Check out this thread about using a coil from a Harley Davidson....much cheaper Share this post Link to post Share on other sites
midpack 1,144 #5 Posted July 20, 2019 You look at the points, check the gap? Maybe a tune up would help. I dont know if a rectifier is an either works or it dont, but start with the small $$ stuff first. Share this post Link to post Share on other sites
953 nut 66,080 #6 Posted July 21, 2019 I had a similar problem on my 418-C (basically same tractor), With the fuel tank being located under the seat (low) and the fuel pump on top of the engine (two feet higher) if your fuel pump is marginal the fuel pressure will be low and it can take a long time for it to prime. I replaced mine with an electric low pressure pump mounted low on the frame and all of the problems went away. Share this post Link to post Share on other sites
Jpbugeye 3 #7 Posted July 21, 2019 Thanks for the response, I can easily hook one up to try..maybe after the heat wave..Jamie Share this post Link to post Share on other sites
BIGGS 5 #8 Posted July 21, 2019 (edited) Hi Jamie, I`m in Conshohocken also. We should meet sometime and talk Wheel Horse. Bigg`s Edited July 21, 2019 by BIGGS Share this post Link to post Share on other sites
Jpbugeye 3 #9 Posted July 22, 2019 16 hours ago, BIGGS said: Hi Jamie, I`m in Conshohocken also. We should meet sometime and talk Wheel Horse. Bigg`s That would be fun, I have a few others like cub cadet, ford and elenco 4wd tractors..610 832 9867...Jamie..I am usually around sat thru monday.. Share this post Link to post Share on other sites
Jpbugeye 3 #10 Posted July 24, 2019 Hi everyone, thanks for the help. It was the coil, got one for about $31..runs well now, easy fix for once! 2 Share this post Link to post Share on other sites
