chev0545 236 #1 Posted July 17, 2019 will a 22hp preador work on a 520 ? thanks Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #2 Posted July 17, 2019 Just now, chev0545 said: will a 22hp preador work on a 520 ? thanks Yes many threads/posts on here about the swap in 520s C series ect... Just have to do some fabricating with the muffler, engine plate and PTO shaft and maybe even converting to an electric PTO... Good luck as I myself haven't done anything like this yet. 1 Share this post Link to post Share on other sites
Kurt-NEPA 755 #3 Posted July 17, 2019 I've followed a number of projects that did the swap. Seemed straight forward. A search should pick up several threads. If memory serves me (and that is a big if). You need to pick up the engine about 1-1/4 to line up the shaft. I think the output shaft is 1" OD. You can get 1" to 1-1/8" adapter with a extra wide key on flea bay so you can used the original PTO. You also need to get creative with the muffler. I know some have used the original PTO with some fabrication work and reported good luck. But there is concern over putting the PTO thrust on an engine without thrust bearings. I have not seen a long term result from doing this. An electric is always an option. If you decide to do this swap, keep us posted. 1 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #4 Posted July 17, 2019 53 minutes ago, Kurt-NEPA said: I've followed a number of projects that did the swap. I know some have used the original PTO with some fabrication work and reported good luck. But there is concern over putting the PTO thrust on an engine without thrust bearings. I have not seen a long term result from doing this. An electric is always an option. If you decide to do this swap, keep us posted. The specs says "ball bearing supported crankshaft" what ever that means... 1 Share this post Link to post Share on other sites
Kurt-NEPA 755 #5 Posted July 17, 2019 3 hours ago, WVHillbilly520H said: The specs says "ball bearing supported crankshaft" what ever that means... Can ball bearings take a side load? I think they can up to a point. ????????? 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #6 Posted July 17, 2019 5 hours ago, WVHillbilly520H said: Yes many threads/posts on here about the swap in 520s C series ect... Just have to do some fabricating with the muffler, engine plate and PTO shaft and maybe even converting to an electric PTO... Good luck as I myself haven't done anything like this yet. Share this post Link to post Share on other sites
Howie 900 #7 Posted July 18, 2019 That is what is in your Kohler k series. Share this post Link to post Share on other sites
chev0545 236 #8 Posted July 18, 2019 20 minutes ago, Howie said: That is what is in your Kohler k series. it's a 520 onan Share this post Link to post Share on other sites
chev0545 236 #9 Posted July 18, 2019 6 hours ago, WVHillbilly520H said: Yes many threads/posts on here about the swap in 520s C series ect... Just have to do some fabricating with the muffler, engine plate and PTO shaft and maybe even converting to an electric PTO... Good luck as I myself haven't done anything like this yet. the valve seals you can pull out with your fingers on the 520 Share this post Link to post Share on other sites
