chev0545
engine
chev0545
will a 22hp preador work on a 520 ?
thanks
WVHillbilly520H
thanks
Yes many threads/posts on here about the swap in 520s C series ect... Just have to do some fabricating with the muffler, engine plate and PTO shaft and maybe even converting to an electric PTO... Good luck as I myself haven't done anything like this yet.
Kurt-NEPA
I've followed a number of projects that did the swap.  Seemed straight forward.  A search should pick up several threads.  If memory serves me (and that is a big if).  You need to pick up the engine about 1-1/4 to line up the shaft.  I think the output shaft is 1" OD.  You can get 1" to 1-1/8" adapter with a extra wide key on flea bay so you can used the original PTO.  You also need to get creative with the muffler.
I know some have used the original PTO with some fabrication work and reported good luck.  But there is concern over putting the PTO thrust on an engine without thrust bearings.  I have not seen a long term result from doing this.  An electric is always an option.
If you decide to do this swap, keep us posted.
  • Thanks 1
WVHillbilly520H
The specs says "ball bearing supported crankshaft" what ever that means...
Kurt-NEPA
Can ball bearings take a side load?  I think they can up to a point.  ?????????
The Tuul Crib
:text-yeahthat: :wwp:
Howie
That is what is in your Kohler k series.
chev0545
it's a 520 onan
chev0545
 the valve seals you can pull out with your fingers on the 520
