19richie66 17,951 #101 Posted August 11, 2019 Looks nice Kevin.👍 1 Share this post Link to post Share on other sites
Tractorhead 9,218 #102 Posted August 12, 2019 Good work Buddy, still Curious for the Final. Share this post Link to post Share on other sites
Pullstart 71,567 #103 Posted August 12, 2019 Final inspection day! He’ll be here in an hour and hasn’t yet seen it in person! We did a design change on the legs, to keep it as close to the ground as possible. I’ll cut some 1/8” plate to place under the set screws, to push against the carpet floor. 2 2 Share this post Link to post Share on other sites
953 nut 70,664 #104 Posted August 12, 2019 1 hour ago, pullstart said: We did a design change on the legs, to keep it as close to the ground as possible I think I would use a hex head cap screw, unless the floor is perfectly level you will need some adjustment. Share this post Link to post Share on other sites
Pullstart 71,567 #105 Posted August 12, 2019 The set screws are 1/2” long and should allow for an 1/8” to 1/4” adjustment and still support the assembly... I hope! Share this post Link to post Share on other sites
WHNJ701 4,173 #106 Posted August 12, 2019 can you post a pic of the entire piece Share this post Link to post Share on other sites
Pullstart 71,567 #107 Posted August 12, 2019 Within a week or two, I’ll have the wood top married to this. I still haven’t seen the wood... and I’m so excited! 1 Share this post Link to post Share on other sites
953 nut 70,664 #108 Posted August 12, 2019 2 hours ago, pullstart said: Within a week or two, I’ll have the wood top married to this. I still haven’t seen the wood... and I’m so excited! Lets see, 700 pounds +/- of steel. Probably that much wood weight added to that! How are you planning to move it into the meeting room it will be used in? Levitation? 2 Share this post Link to post Share on other sites
Pullstart 71,567 #109 Posted August 12, 2019 Strong backs, weak minds! 2 1 Share this post Link to post Share on other sites
diesel cowboy 263 #110 Posted August 13, 2019 4 hours ago, pullstart said: Strong backs, weak minds! Ah the old brute strength and ignorance method. Done that a few times myself and have a few people I call to help with it sometimes too. Been an interesting project to watch, can't wait to see it with the top on it. I really enjoy seeing different things like this being made. Share this post Link to post Share on other sites
Pullstart 71,567 #111 Posted August 14, 2019 Sneak peak of the slab! This was my first glimpse of the rest of the story! I built some quick straps to help prevent cupping and separating on the ends of the seam and used the threaded inserts to hold one end down for now. 4 1 1 2 Share this post Link to post Share on other sites
Tractorhead 9,218 #112 Posted August 15, 2019 Whow, buddy what a cool lookin. A big advantage is, a theft protection is maybe not needed, because of weight.. 😂👍 How you like to protect the Surface ? Using Oil, Wax or Clearcoat? Share this post Link to post Share on other sites
Pullstart 71,567 #113 Posted August 15, 2019 They are using a dark oil. I should have taken a picture of the cabinetry because it was all milled out of the same tree! I will once it’s complete! 1 1 1 Share this post Link to post Share on other sites
Pullstart 71,567 #114 Posted August 31, 2019 I received these pictures from the customer last night. The table top needs to be drilled now for inserts then we can screw the two together. There will be ivory in the chairs and all the cabinetry handles are deer antler. All the woodwork is from the same tree, remember! 4 6 5 Share this post Link to post Share on other sites
Tractorhead 9,218 #115 Posted August 31, 2019 Whow, that is more than awesome. it looks like it was grown that Way. pretty Cool Job you did Kevin. Congrats. I hope the Customer honest the Work. Respect! 1 Share this post Link to post Share on other sites
ebinmaine 81,289 #116 Posted August 31, 2019 36 minutes ago, Tractorhead said: more than awesome. Agreed Share this post Link to post Share on other sites
Stormin 9,988 #117 Posted August 31, 2019 Lovely job. Looks quite art deco. Share this post Link to post Share on other sites
19richie66 17,951 #118 Posted August 31, 2019 Turned out great! Share this post Link to post Share on other sites
The Tuul Crib 7,354 #119 Posted August 31, 2019 Nice lookin slab! It all turned out great ! So whats the next project? I have a nice 3 foot diameter sycamore tree that fell during the last storm we had! If you look closely you can see a black and tan on tap! I mean on top! 3 1 Share this post Link to post Share on other sites
Tractorhead 9,218 #120 Posted August 31, 2019 1 hour ago, The Tool Crib said: Nice lookin slab! It all turned out great ! So whats the next project? I have a nice 3 foot diameter sycamore tree that fell during the last storm we had! If you look closely you can see a black and tan on tap! I mean on top! So mean that, we know what‘s your next Project? 😎 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #121 Posted August 31, 2019 2 minutes ago, Tractorhead said: So mean that, we know what‘s your next Project? 😎 Maybe ! Will be tough to get this one out to the mill! Share this post Link to post Share on other sites
ebinmaine 81,289 #122 Posted August 31, 2019 3 minutes ago, The Tool Crib said: Will be tough to get this one out to the mill! Might need something bigger than a Wheelhorse..... 1 Share this post Link to post Share on other sites
Tractorhead 9,218 #123 Posted August 31, 2019 2 minutes ago, ebinmaine said: Might need something bigger than a Wheelhorse..... Yap, 2 or 3 Wheelhorses, connected by Chains... 😂 1 Share this post Link to post Share on other sites
Stormin 9,988 #124 Posted August 31, 2019 If I had anything to do with it, it wouldn't be going to any sawmill. 1 Share this post Link to post Share on other sites
Tractorhead 9,218 #125 Posted August 31, 2019 Found a nice idea, could also be made with a Wheelhorse... Can be a cool Project.. 1 Share this post Link to post Share on other sites
