AHS 1,559 #1 Posted July 16, 2019 A C105 with a 42” rear discharge for $300! And it runs! And smokes, But there is some oil from the head gasket area. Bad head gasket? Warped head? how much can you shave the head on these K series motors? All the questions!🇺🇸🇺🇸 2 Share this post Link to post Share on other sites
ebinmaine 74,518 #2 Posted July 16, 2019 Nice purchase! As to the Head shaving. That can be done with a piece of glass or known flat Steel and some sandpaper taped to the face of it. There are good videos about that available on YouTube. It is a bit time consuming but does work quite well. 1 Share this post Link to post Share on other sites
ohiofarmer 3,383 #3 Posted July 16, 2019 (edited) If you do take off the head, do some other things while you are in there. Buy a Harbor Freight bore gauge and compare the diameter on the wrist pin side with the areas 90 degrees from the wrist pin. You really can not keep them from smoking if the cylinder is egg shaped. Also adjust those valves. It might be the thing to do before you pull the head just in case the valves are the source of the smoke. There is also a baffle thingy inside the valve cover that must be installed right side up to avoid that smoke. I am not sure if it CAN be installed wrong, but there are plenty of people here smarter than me who know the answer. Anyway, with previous owners making mistakes with wrenches, it falls on you to figure it all out. BTW,you killed at that price if the engine is sound Edited July 16, 2019 by ohiofarmer 1 Share this post Link to post Share on other sites
953 nut 62,129 #4 Posted July 16, 2019 Prior to doing any disassembly I like to clean the engine well and run it to see where the leak really is. 2 hours ago, ohiofarmer said: must be installed right side up to avoid that smoke. I am not sure if it CAN be installed wrong, Yes it can be installed upside down! Please don't ask how I know this. 1 1 Share this post Link to post Share on other sites
ebinmaine 74,518 #5 Posted July 16, 2019 14 minutes ago, 953 nut said: Yes it can be installed upside down! Please don't ask how I know this. Mmmmm.... Yepp..... Me too...... 1 Share this post Link to post Share on other sites
Blackhood Bill 722 #6 Posted July 16, 2019 Not to side track the conversation but Share this post Link to post Share on other sites
SylvanLakeWH 29,303 #7 Posted July 16, 2019 My C105 welcomes a cousin to !!! Love the Black Hoods!!! 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 23,762 #8 Posted July 16, 2019 Mine isn’t as pretty as the one pictured above, but’s its a great worker! (She ain’t shiny, tractors wet in the pic) 3 Share this post Link to post Share on other sites
AHS 1,559 #9 Posted July 16, 2019 Love the beer on the hood!!👍 ok, I will check the bore, and adjust the valves. Great info on here! Thank you guys!! 2 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #10 Posted July 16, 2019 1 hour ago, SylvanLakeWH said: My C105 welcomes a cousin to !!! Love the Black Hoods!!! Better finish that beer before it heats up! 1 1 1 Share this post Link to post Share on other sites
AHS 1,559 #11 Posted July 18, 2019 Oh, how much oil? 2.5 qts? I am used to doing the oil on my 312 small block! i need to do the tranny oil cause the shifter boot is ripped. 80w90, for the tranny? Share this post Link to post Share on other sites
tunahead72 2,581 #12 Posted July 18, 2019 Mmm... I think 2.5 quarts is too much. Check the owner's manual for your tractor if you have one (there's one here on RedSquare somewhere), I believe my 1981 C-105 only takes 1.5 quarts. 80W90 is fine for the tranny. Share this post Link to post Share on other sites
pfrederi 18,966 #13 Posted July 18, 2019 Full size oil pans used when engine bolted to frame are about 2.5 ats. The Isolation mounts used on some C series like Black hoods used a smaller oil pan held less oil. Share this post Link to post Share on other sites
