slapshot 2 #1 Posted July 7, 2019 (edited) I'm gathering info and parts for the B80 (1977) of my friends, and since it's 55 miles away, I like to have as much gathered as possible when I go to work on it. I think the last thing I need is to know what size the fuel line is, and how much do I need to renew it from the gas tank to the carb? Any suggestions as to type? Thanks for all your help! These are neat tractors! BTW, he's buying a new battery for it this week... Edited July 7, 2019 by slapshot Share this post Link to post Share on other sites
pfrederi 20,662 #2 Posted July 7, 2019 1/4" get 3 feet to give your self room for error. 1 Share this post Link to post Share on other sites
ebinmaine 79,127 #3 Posted July 7, 2019 23 minutes ago, pfrederi said: 1/4" get 3 feet to give your self room for error. 25 minutes ago, slapshot said: Any suggestions as to type? I don't use rubber anymore. We don't use ethanol gasoline in any of our own machines. Every once in awhile I help someone fix theirs and I don't know if they use ethanol. That's why I've stopped using rubber fuel line. I've switched over to a blue see-through hose I buy from Lincoln at A To Z. You can also use yellow tygon. Tygon or other see-through gasoline safe tubing would be available at a lot of auto parts stores or small engine repair shops. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #4 Posted July 8, 2019 The auto parts stores should be selling ethanol resistant 1/4" rubber hose, my local store of choice does...https://mossmotors.com/barricadetm-ethanol-proof-fuel-hose-by-gates 2 Share this post Link to post Share on other sites
