cafoose 3,817 #1 Posted July 6, 2019 I went to harbor freight and bought one of their portable sheds for some of my horses. I got the extended warranty so if anything happens to it in three years I get a new one! It tells you just to slip the pipes together but I put a duct work screw in each pipe and also screwed it to a heavy 4 x 4 frame to hold it down. 8 Share this post Link to post Share on other sites
Achto 32,429 #2 Posted July 6, 2019 I've looked at getting one of those, The only thing that they are lacking is ventilation. I've heard some people complain about the condensation inside of those structures. You might wish to devise a way to add some gable vents. 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #3 Posted July 6, 2019 Is that the 10 x 17 model? Share this post Link to post Share on other sites
cafoose 3,817 #4 Posted July 6, 2019 1 hour ago, elcamino/wheelhorse said: Is that the 10 x 17 model? Yes it is Share this post Link to post Share on other sites
ebinmaine 80,434 #5 Posted July 6, 2019 With an asphalt base you should have minimal condensation issue. We are finding that it's like a sauna on the hot days we've been having. We may consider adding a vent to ours. 1 Share this post Link to post Share on other sites
cafoose 3,817 #6 Posted July 6, 2019 1 hour ago, ebinmaine said: With an asphalt base you should have minimal condensation issue. We are finding that it's like a sauna on the hot days we've been having. We may consider adding a vent to ours. I'm thinking about a vent myself. After work last night I noticed condensation on the inside of the cover although it was raining when I got home. Yesterday morning as I was finishing up the inside I was sweating like a pig and I normally don't sweat much I believe I do need some sort of ventilation. 1 Share this post Link to post Share on other sites
ebinmaine 80,434 #7 Posted July 6, 2019 4 minutes ago, cafoose said: I'm thinking about a vent myself. After work last night I noticed condensation on the inside of the cover although it was raining when I got home. Yesterday morning as I was finishing up the inside I was sweating like a pig and I normally don't sweat much I believe I do need some sort of ventilation. DEFINITELY 1 Share this post Link to post Share on other sites
JoeM 10,183 #8 Posted July 6, 2019 Good buy on the extended warranty. My son and another person both had those and the lasted just a little more than a year. Keep the snow off too, not much support for snow load. I know my son would leave the front unzipped to leave air in and close it up during high wind. 1 Share this post Link to post Share on other sites
WHNJ701 4,173 #9 Posted July 6, 2019 biggest issue is the snow load, I have a shelter logic that is 12 years old and has been moved to 2 different properties, I added some emt conduit along the roof. it sucks, but you have snow off asap, I also have the upgraded 10 year cover on it which is really heavy duty. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #10 Posted July 6, 2019 I have been thinking about getting one from HF if I wait unit 25% discount coupon it is a great deal . I think if you put a moister barrier on the ground it would cut down on moister and rust problem. Share this post Link to post Share on other sites
cafoose 3,817 #11 Posted July 6, 2019 43 minutes ago, elcamino/wheelhorse said: I have been thinking about getting one from HF if I wait unit 25% discount coupon it is a great deal . I think if you put a moister barrier on the ground it would cut down on moister and rust problem. Actually I tried using a 20% discount coupon and they said it does not apply to the shed if you read the small print Share this post Link to post Share on other sites
rmaynard 17,547 #12 Posted July 6, 2019 (edited) There are small openings in the gables, however on mine I added a little assistance. This is a cheap bathroom fan that is vented out the rear gable. Even though I have the ground covered with plastic, the humidity level gets so high that it "rains" even with the fan going 24/7. Most things that are not in sealed containers have been water damaged. I live within 20 miles of Cafoose, so the weather conditions are the same. As far as snow load, we have had some major snows within the last 3 years, and I have had no problems. Edited July 6, 2019 by rmaynard 1 1 Share this post Link to post Share on other sites
cafoose 3,817 #13 Posted July 6, 2019 (edited) 33 minutes ago, rmaynard said: There are small openings in the gables, however on mine I added a little assistance. This is a cheap bathroom fan that is vented out the rear gable. Even though I have the ground covered with plastic, the humidity level gets so high that it "rains" even with the fan going 24/7. Most things that are not in sealed containers have been water damaged. I live within 20 miles of Cafoose, so the weather conditions are the same. As far as snow load, we have had some major snows within the last 3 years, and I have had no problems. Good idea I may just do that. Hopefully being on asphalt I won't have a lot of condensation I think when it's nice out I will leave the door up. Maybe a bigger fan than yours would be better? https://www.lowes.com/pd/Air-Vent-18-in-Dia-Electric-Gable-Vent-Fan/3143421 Maybe these on either end? https://www.lowes.com/pd/Master-Flow-20-75-in-x-26-75-in-White-Rectangle-Plastic-Gable-Vent/1000069555 Edited July 6, 2019 by cafoose Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #14 Posted July 6, 2019 1 hour ago, cafoose said: Actually I tried using a 20% discount coupon and they said it does not apply to the shed if you read the small print Crap , there goes my wallet 1 Share this post Link to post Share on other sites
rmaynard 17,547 #15 Posted July 7, 2019 There isn't enough room for a big fan. That is why I used 4" inch flexible duct. Share this post Link to post Share on other sites
ebinmaine 80,434 #16 Posted July 7, 2019 2 minutes ago, rmaynard said: There isn't enough room for a big fan. That is why I used 4" inch flexible duct. What did you put in for the Gable end? Share this post Link to post Share on other sites
