The Tuul Crib 7,354 #1 Posted June 29, 2019 Got the Husky out this morning because my next-door neighbor called me and said he had some trees down from the last storm on the farm. So I said sure I’ll bring my saw and ran around the corner.When I got there one of the trees was a straight tall Walnut about thirty feet long and about a foot in diameter. I couldn’t resist it I’ve got at least 30 feet of straight 12 inch. Got one word for this.... Bowls!!!! Alot of turnings! 2 6 Share this post Link to post Share on other sites
adsm08 5,167 #2 Posted June 29, 2019 Nice score! My dad had a walnut come down the Friday of the show. It was bigger around, but not as straight. I pulled a coupe chunks to try and preserve and make lamps from. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #3 Posted June 29, 2019 I found something cool to do on a hot 90° plus day . Had to pressure wash the pieces before I brought them in the house. Sure felt good to get wet !! 1 3 1 Share this post Link to post Share on other sites
ebinmaine 80,777 #4 Posted June 29, 2019 3 hours ago, adsm08 said: Nice score! Agreed Of course Randy will be sharing pics as he makes stuff .... Right?? 1 Share this post Link to post Share on other sites
adsm08 5,167 #5 Posted June 29, 2019 4 hours ago, The Tool Crib said: I found something cool to do on a hot 90° plus day . Had to pressure wash the pieces before I brought them in the house. Sure felt good to get wet !! Why does this look incredibly photoshopped? 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #6 Posted June 29, 2019 12 minutes ago, adsm08 said: Why does this look incredibly photoshopped? No it is real as rain. These are two logs l cut this morning. Im too old for all that fancy stuff!!!! Share this post Link to post Share on other sites
The Tuul Crib 7,354 #7 Posted June 29, 2019 59 minutes ago, ebinmaine said: Agreed Of course Randy will be sharing pics as he makes stuff .... Right?? Of course!! Working on getting an aggressive chain to split the log! Any ldeas? Share this post Link to post Share on other sites
adsm08 5,167 #8 Posted June 29, 2019 3 minutes ago, The Tool Crib said: No it is real as rain. These are two logs l cut this morning. Im too old for all that fancy stuff!!!! It's probably the lighting, it just looks like the background scenery, you, and the logs all came from different photos. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #9 Posted June 29, 2019 (edited) 3 minutes ago, adsm08 said: It's probably the lighting, it just looks like the background scenery, you, and the logs all came from different photos. Nope thats my neighborhood! That poplar behind me is over 2 foot in diameter and over 100 feet tall ! Edited June 29, 2019 by The Tool Crib Share this post Link to post Share on other sites
JCM 11,417 #10 Posted June 29, 2019 That Maroon stripe Wheelhorse look's awful nice in the background,400 Series ? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #11 Posted June 29, 2019 Yeah thats my 414 -8 . It has low hours on it l mow a little with it and just ride it around and look pretty!!! 1 Share this post Link to post Share on other sites
ebinmaine 80,777 #12 Posted June 29, 2019 1 hour ago, The Tool Crib said: Of course!! Working on getting an aggressive chain to split the log! Any ldeas? When you say "split the log" do you mean cut it lengthwise? Or are you just looking for a more aggressive chain to cut those into smaller pieces? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #13 Posted June 29, 2019 3 minutes ago, ebinmaine said: When you say "split the log" do you mean cut it lengthwise? Or are you just looking for a more aggressive chain to cut those into smaller pieces? Yes . I want to rip length wise then cross cut for bowl turnings Share this post Link to post Share on other sites
wallfish 20,639 #14 Posted June 30, 2019 https://www.toolcenter.com/RIPPING_CHAIN.html 1 Share this post Link to post Share on other sites
ebinmaine 80,777 #15 Posted June 30, 2019 32 minutes ago, The Tool Crib said: Yes . I want to rip length wise then cross cut for bowl turnings I'm kind of thinking your best bet is to find a local person with a portable sawmill. Around here they only get 25 or 50 cents a foot to cut. Another option would be to do a search on YouTube or whatever for a hand chainsaw Mill using a 2 x 4 and the above-listed ripping chain by John. @wallfish Share this post Link to post Share on other sites
ztnoo 2,302 #16 Posted June 30, 2019 Just for consideration: chain saw mills. https://www.google.com/search?q=chainsaw+mill&client=firefox-b-1-d&source=lnms&tbm=shop&sa=X&ved=0ahUKEwjcrN-b-Y_jAhWDBs0KHaHjBPEQ_AUIECgB&biw=1920&bih=947 Share this post Link to post Share on other sites
ebinmaine 80,777 #17 Posted June 30, 2019 2 minutes ago, ztnoo said: Just for consideration: chain saw mills. https://www.google.com/search?q=chainsaw+mill&client=firefox-b-1-d&source=lnms&tbm=shop&sa=X&ved=0ahUKEwjcrN-b-Y_jAhWDBs0KHaHjBPEQ_AUIECgB&biw=1920&bih=947 I have basically zero experience operating a mill of any size. Can something like that be used to cut a log directly in half or do you need to remove a certain amount at a time? I was always under the impression that a lot of those had a 2" depth Max cut. Share this post Link to post Share on other sites
ztnoo 2,302 #18 Posted June 30, 2019 (edited) Eric, Generally speaking I'd say that assumption is correct. But then I stumbled upon this, so I imagine there are multiple possibilities if one is deadly serious about doing it own their own and willing to research the possibilities. https://outermart.com/products/mophoto-chainsaw-mill-14-to-36-chain-saw-planking-milling-guide-bar-portable-aluminum-steel-chainsaw-mill-wood-lumber-cutting-builders-a?gclid=EAIaIQobChMI3umL-_qP4wIVTJyzCh0ANAfZEAkYCyABEgKPE_D_BwE Otherwise, I say load those logs up and take them to the nearest commercial sawmill and tell them what you want. Voila! Edited June 30, 2019 by ztnoo 1 Share this post Link to post Share on other sites
JCM 11,417 #19 Posted June 30, 2019 (edited) I have found that the local Mills want nothing to do with trees that are cut down near the house because of potential metal objects in them when they saw them, I even had 3 fifty plus footers that were taken down 300 yards from the house, 2 pines and 1 hemlock and they sat for 2 years because I had someone who wanted them but never came to pick them up, so into the log splitter they went and are now destined for the outdoor fire pit. Edited June 30, 2019 by JCM 1 Share this post Link to post Share on other sites
