GregM 0 #1 Posted June 24, 2019 Hello. If someone could please guide me in the right direction. C-175 Wheel Horse. Nothing at switch. Replaced ignition switch, and starter solenoid. Still nothing. Fuses look good. No broken or corroded wires or connectors that I see. I probably shouldn't have, but I shorted the solenoid and got crank but no start. Please HELP! Share this post Link to post Share on other sites
ztnoo 2,302 #2 Posted June 24, 2019 This would probably be a better question to ask in Wheel Horse Electrical section of the forum. Just a heads up...... https://www.wheelhorseforum.com/forum/65-wheel-horse-electrical/ Share this post Link to post Share on other sites
rmaynard 16,843 #3 Posted June 24, 2019 Check the connections at the back of the ammeter. 2 Share this post Link to post Share on other sites
Herder 2,355 #4 Posted June 24, 2019 Safety switches. Check for PTO engagement, tractor will not start if the PTO is engaged. (Safety Switch) Check seat and possible drake/clutch switches use a test light if you have one or jump them out one at a time.to Red Square, post some pics when you get her running. Share this post Link to post Share on other sites
Lee1977 7,547 #5 Posted June 24, 2019 8 speed or hydro? If you tell witch it is you will get better answers as to where to look for your problem. Share this post Link to post Share on other sites
prondzy 3,889 #6 Posted June 24, 2019 Is the ammeter bad? Share this post Link to post Share on other sites
GregM 0 #7 Posted June 24, 2019 Honestly I'm not sure how the ammeter should be connected. Currently it has no corrosion and is connected to the +battery post. Share this post Link to post Share on other sites
rmaynard 16,843 #8 Posted June 24, 2019 The ammeter is in series with the + wire coming from the battery to the ignition switch, meaning that all current flows through that wire, with the exception of the starter. To eliminate the ammeter as a problem you can remove the wires and hook them together. 2 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #9 Posted June 24, 2019 1 hour ago, Herder said: Safety switches. Check for PTO engagement, tractor will not start if the PTO is engaged. (Safety Switch) Check seat and possible drake/clutch switches use a test light if you have one or jump them out one at a time.to Red Square, post some pics when you get her running. and to Share this post Link to post Share on other sites
