The Tuul Crib 7,354 #1 Posted June 22, 2019 (edited) I’ve been looking around at different places today for a pair of LED bulbs to fit the 1156 socket on my 60s tractor. Can’t seem to locate what I’m looking for until I looked online and found them at I Save Tractors.com. Has anyone tried these bulbs from Norman yet ? Are they very bright? It says they are 1000 lummens. The price is definitely rite! Edited June 23, 2019 by The Tool Crib Share this post Link to post Share on other sites
Achto 32,795 #2 Posted June 23, 2019 I have these installed on my Raider 12. They are not halogens but they are fairly bright. Share this post Link to post Share on other sites
Anglo Traction 761 #3 Posted June 23, 2019 A 60s Wheel Horse Light unit should be similar to the version in my topic here where I had to improve on the Light buckets to make max use of the LEDs. With the reduction in heat, I decided to also block of the vents. About halfway down this page(3) in post #68 may offer you some assistance- 74 C-120/Raider update Share this post Link to post Share on other sites
doc724 927 #4 Posted June 23, 2019 I would be a little bit cautious. I put a set of aftermarket LED bulbs in the rear lens of my 520xi. (not the same ones as above). Although LED's do not draw as much current, somehow, the socket where the bulb fit became damaged from heat. I threw them out. I also had the 1156 (I think) LED bulb in the front lights. I was not impressed and threw them out also. If LED's are designed into a light with proper reflector design, they are great. I actually bought complete LED lens assemblies for the rear of my 314 and they were awesome. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #5 Posted June 23, 2019 I lined the bezel with some silver HVAC tape to see if that would help reflect some Share this post Link to post Share on other sites
rjg854 13,383 #6 Posted June 23, 2019 I've used the 1156 led bulbs in the headlight buckets on my Commandos, haven't had any sort of problem if fact I was very well pleased with just how much better light they produced. A wonderful improvement. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #7 Posted June 24, 2019 Every led replacement I have come across has the leds aimed at the top of the bulb which won't work in the WH housing. Ones aimed to the side of the bulb can not be very popular. Garry Share this post Link to post Share on other sites
The Tuul Crib 7,354 #8 Posted June 28, 2019 (edited) I just received my LED bulbs from Amazon and put them in IRV and was amazed how brite they are! These bulbs have diodes on top. I lined the bezel on the back and the top which seemed to help. Edited June 28, 2019 by The Tool Crib Share this post Link to post Share on other sites
The Tuul Crib 7,354 #9 Posted July 1, 2019 Here’s jn my shop with the lites out. At least l know l can work in my shop now when the power goes out!! Share this post Link to post Share on other sites
IndyFord2 52 #10 Posted September 5, 2019 I upgraded several years ago. Don't mow at night, but on occasion need to see. 90% of my LED's come from "superbrightled.com". Its not fancy but this is my C-120. they are a direct replacement for a 1156 bulb 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #11 Posted September 6, 2019 These are great bulbs ! I didnt want to change the old sockets and keep them original ! This worked great ! Now lm ready to plow snow this winter! Bring it!! Share this post Link to post Share on other sites
