HerbS 6 #1 Posted June 16, 2019 I'd like to clean the shutoff valve but am unsure how to get it off the tank. Can anyone help? Thanks. Share this post Link to post Share on other sites
JAinVA 4,638 #2 Posted June 16, 2019 The fuel shutoff valve is pushed in to the rubber grommit at the bottom of the tank.It is removed by pulling and twisting at the same time.It will come out but unless the tank is empty you will get a bath. 1 Share this post Link to post Share on other sites
HerbS 6 #3 Posted June 16, 2019 Thanks. Should be easy enough. Share this post Link to post Share on other sites
953 nut 70,344 #4 Posted June 16, 2019 You will probably need a new rubber grommet or it is likely to leak when you put the valve back in. Might as well have it on hand before doing the job. 2 Share this post Link to post Share on other sites
