PAguy 8 #1 Posted June 15, 2019 I have a Toro wheel horse 314 and I have two questions. One noticed when in 2nd the shifter does not lock tight and seems loose it will hold in place and drives but is not locked tight like in the other gears. Second, the manual says nothing about changing the transmission fluid. Just to check the level. Should it be changed? And if yes what's the best way to do that without causing damage to the transmission? This was my grandfathers and I am sure he never changed out the fluid. Share this post Link to post Share on other sites
953 nut 65,274 #2 Posted June 15, 2019 Glad to see you will be giving your Grandfather's some love. 6 hours ago, PAguy said: noticed when in 2nd the shifter does not lock tight and seems loose Your shift lever is retained bu a "Dog-point Screw that may need to be tightened. 6 hours ago, PAguy said: the manual says nothing about changing the transmission fluid. Just to check the level. Should it be changed? And if yes what's the best way to do that without causing damage to the transmission? Good idea to replace the gear oil . The drain plug is near the back of the transmission near the trailer hitch. It takes an allen wrench to remove the plug. You should jack up the front end to be sure all the old oil drain. You will need two quarts of 80-90 gear oil to refill, slow and easy when adding the oil or it will burp out and make a mess. 2 Share this post Link to post Share on other sites
ebinmaine 78,300 #3 Posted June 15, 2019 13 minutes ago, 953 nut said: drain plug is near the back of the transmission near the trailer hitch..... On the BOTTOM of the case. It isn't the one on the side. It will be a while draining because of thickness. I give mine overnight if I can but minimum an hour or two. You can also flush the transmission using K1 or diesel and drive it around a bit to help cleanse the gears. It's a great idea to replace the shift boot if you haven't already done so. Keep us posted about the color and consistency of the fluid. It often resembles taffy or caramel which is delicious but not what should be in there. 2 1 Share this post Link to post Share on other sites
CCW 1,493 #4 Posted June 15, 2019 The shift boot on my 312-8 (inherited from parents after dad passed) was loose, but in good condition. Put it back on but popped out of place again. Solved the problem by putting a small hose clamp around the top of the boot. No more water in the tranny when I changed again this spring. 2 Share this post Link to post Share on other sites
pfrederi 20,273 #5 Posted June 15, 2019 Drain plug is 1/4" allen probably packed with crud you will; need to clean out first. 3 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #6 Posted June 15, 2019 Heres what l use. Its a plumbers tool . lt is just the right size to fit the drain plug. Share this post Link to post Share on other sites
Herder 2,355 #7 Posted June 15, 2019 1 hour ago, The Tool Crib said: Heres what l use. Its a plumbers tool . lt is just the right size to fit the drain plug. Good thinking. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,155 #8 Posted June 15, 2019 Many realize the pipe plugs are tapered so wind them in singing tight thinking they will not leak. But they will. This type of pipe thread is not meant to seal. The threads require a thread sealer and just snug them up.They won't fall out. Makes them much easier to get out next time. Garry 1 Share this post Link to post Share on other sites
ebinmaine 78,300 #9 Posted June 15, 2019 1 minute ago, gwest_ca said: Many realize the pipe plugs are tapered so wind them in singing tight thinking they will not leak. But they will. This type of pipe thread is not meant to seal. The threads require a thread sealer and just snug them up.They won't fall out. Makes them much easier to get out next time. Garry Mental note.... Stop using 5 foot bar on transmission plugs.... Seriously though.... Teflon tape ok? Share this post Link to post Share on other sites
71_Bronco 1,072 #10 Posted June 15, 2019 I changed the fluid in my Commando 8 when I got it. I didnt use any sealer on the plug, just cleaned it up and snugged it in. Thays how it was when I pulled it out. Havent had a leak, and it's been a few weeks now. I know its leaking a little from the axle seals (couple drips when I go on a slope), but nothing from the plug. I'll keep an eye on it to make sure nothing happens. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #11 Posted June 16, 2019 Same here the plug was fine for me. No teflon tape , just a good snug tightening. No leaks 1 Share this post Link to post Share on other sites
pfrederi 20,273 #12 Posted June 16, 2019 Never used any thing on any of mine no leaks. if you have a hydro and use teflon tape you better hope no little part comes off. The acceleration valve holes on a sunsdstrand are very very samall and a bit of tape (or RTV) will plug them up. 2 Share this post Link to post Share on other sites
