Brent Fabian 57 #1 Posted June 7, 2019 I believe this is called the Sector gear for my wheel horse suburban. I only have 1 to use with both my tractors, and I discovered today one of the teeth is missing. Anybody have new ones for sale or a way to get a new one? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #2 Posted June 7, 2019 Wow! I don’t know where to get one of these but lm sure someone has one somewhere. Good luck in your search! Share this post Link to post Share on other sites
71_Bronco 1,072 #3 Posted June 7, 2019 Possibly try AZ Tractors in the classifieds section? Could try Ebay too, but try generic terms like "wheel horse suburban", as the seller may not know the exact name of it or part number. Share this post Link to post Share on other sites
953 nut 66,605 #4 Posted June 7, 2019 If you can weld and have the patience to do so you could build up the teeth that are gone and then grind them to the proper shape. Sort of like going to the dentist for a crown. 7 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #5 Posted June 8, 2019 35 minutes ago, 953 nut said: If you can weld and have the patience to do so you could build up the teeth that are gone and then grind them to the proper shape. Sort of like going to the dentist for a crown. Share this post Link to post Share on other sites
ebinmaine 79,153 #6 Posted June 8, 2019 1 hour ago, 71_Bronco said: Possibly try AZ Tractors in the classifieds section? I'd try A-Z. And throw an ad in our own classifieds. Share this post Link to post Share on other sites
AMC RULES 37,259 #7 Posted June 8, 2019 One on Ebay now. 1 1 1 Share this post Link to post Share on other sites
953 nut 66,605 #8 Posted June 8, 2019 24 minutes ago, AMC RULES said: Ebay now. That won't fit a Suburban! 3 Share this post Link to post Share on other sites
wallfish 20,049 #9 Posted June 8, 2019 3 hours ago, Brent Fabian said: Anybody have new ones for sale or a way to get a new one? You would most certainly be able to get them at the big Wheel Horse show in a couple of weeks. 6/21 6/22 Biglerville PA Well worth the drive if you're into anything Wheel Horse. Even more so if you're looking for parts. 2 2 1 Share this post Link to post Share on other sites
Brent Fabian 57 #10 Posted June 8, 2019 5 hours ago, 953 nut said: If you can weld and have the patience to do so you could build up the teeth that are gone and then grind them to the proper shape. Sort of like going to the dentist for a crown. I was thinking of tracing the gear pattern and creating a copy so I have one for both my tractors 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #11 Posted June 8, 2019 What model Suburbans do you have? Share this post Link to post Share on other sites
Brent Fabian 57 #12 Posted June 9, 2019 17 hours ago, AMC RULES said: What model Suburbans do you have? Both are Suburban 400s Share this post Link to post Share on other sites
wallfish 20,049 #13 Posted June 9, 2019 Pretty sure they all use the same part. 400, 550, 401, 551 2 Share this post Link to post Share on other sites
formariz 12,378 #14 Posted June 10, 2019 8 hours ago, wallfish said: Pretty sure they all use the same part. 400, 550, 401, 551 Yes they do. Pretty sure also that that part is unique to them and not used in any other model. Doesn't show up often for sale. Share this post Link to post Share on other sites
Jennifer 1,878 #15 Posted June 10, 2019 (edited) Last one I saw on eBay was this one and Darek Woodman had it. But now you know park number! Edited June 10, 2019 by Jennifer 1 Share this post Link to post Share on other sites
Jennifer 1,878 #16 Posted June 10, 2019 Yes the big show should have one I bought one there last year for 20.00 that was usable! Share this post Link to post Share on other sites
