Mudrig150 386 #1 Posted June 5, 2019 So I bought a kohler magnum 18, it only turns half a turn. Could this be a broken rod or a stuck valve? It has oil and it seems a bit black but it's not silver, so I'm thinking maybe stuck valve? It has been sitting for a while. Share this post Link to post Share on other sites
Achto 31,898 #2 Posted June 5, 2019 (edited) 23 minutes ago, Mudrig150 said: So I bought a kohler magnum 18, it only turns half a turn. Could this be a broken rod or a stuck valve? It has oil and it seems a bit black but it's not silver, so I'm thinking maybe stuck valve? It has been sitting for a while. The valves on a L / flat head engine would not be able to come into contact with the piston. I'm thinking that you may have a broken rod. Pull the heads off & see what's moving & what's not when you turn the crank. Edited June 5, 2019 by Achto 1 Share this post Link to post Share on other sites
Mudrig150 386 #3 Posted June 5, 2019 Yeah but if they were stuck they would stop the camshaft, effectively stopping the engine. Our little clinton had a stuck valve and it acted like a seized, broken rod. Share this post Link to post Share on other sites
Achto 31,898 #4 Posted June 5, 2019 (edited) 3 minutes ago, Mudrig150 said: Yeah but if they were stuck they would stop the camshaft, effectively stopping the engine. This is true. Best bet would be to pull the heads off & see what moves & what doesn't. Edited June 5, 2019 by Achto 1 Share this post Link to post Share on other sites
Mudrig150 386 #5 Posted June 5, 2019 I'm hoping it's just multiple stuck valves, even that would be easier to fix then a broken rod. The oil looks dirty but it doesn't show any characteristics of something broken, such as metal particles. Share this post Link to post Share on other sites
Achto 31,898 #6 Posted June 5, 2019 It looks like you would need to remove the intake & exhaust to get at the valve covers. This would allow you to gently push on the valve spring to see if your valves are free. But I think that pulling the heads to see what's going on might be easier and require less gaskets to reassemble. Hope it's not too serious. Let us know what you find. Share this post Link to post Share on other sites
Mudrig150 386 #7 Posted June 5, 2019 Luckily for me it looks pretty nice, and doesn't appeared to have been sitting outside, but in the kid's little shed. Share this post Link to post Share on other sites
Mudrig150 386 #8 Posted June 5, 2019 Any openings into the block to check if it has broken rod, or do I have to split it? Share this post Link to post Share on other sites
oliver2-44 11,522 #9 Posted June 5, 2019 If your not in a hurry, you might drain the oil and fill everything (crankcase, cylinder. exhaust, intake) full of diesel. Let it set and each day rock the crankshaft a little to see if it would gradually move more and free up. Share this post Link to post Share on other sites
953 nut 66,557 #10 Posted June 5, 2019 7 hours ago, Mudrig150 said: been sitting outside, but in the kid's little shed. Could be the mice have built enough nests under the flywheel cover to keep it from turning. You need to remove them and clean the cooling fins anyway. 1 Share this post Link to post Share on other sites
19richie66 17,892 #11 Posted June 6, 2019 Check the flywheel magnets. Had all of them come off a flywheel. Ran good and then when I shut it off, a small piece caught a pole on the stator. Instant lock up. Moved back and forth a little but when you hit the key, it jammed and acted like it was a broke rod. Toasted the stator but I have another for it. Pulled a spare flywheel and it was the same way. 1 2 Share this post Link to post Share on other sites
Mudrig150 386 #12 Posted June 8, 2019 (edited) Figured it out. As it turns out, the engine does not have a stuck valve or broken rod. What it does have is over 1/8 inch of rust buildup in the bore. I was using super low grit sandpaper and wasn't even making a dent. Guess I'll just need a new jug. My brother suggested it may have had water in it but the carb plates are clean and the intake has no rust in it. My hypothesis is just water vapor getting in through the open valve. Edited June 8, 2019 by Mudrig150 2 Share this post Link to post Share on other sites
Achto 31,898 #13 Posted June 8, 2019 43 minutes ago, Mudrig150 said: Guess I'll just need a new jug. If the jug is removable, you could possibly just have the rusty jug machined and install a new piston & rings on that side. Just a suggestion. A .010 over piston on one side will not hurt any thing at all. 1 Share this post Link to post Share on other sites
ZXT 2,402 #14 Posted June 8, 2019 Any pictures of the rust in the cylinder? I've had more than one engine sit full of water forever and clean up with a hone and run great.. If the cylinder isn't pitted, it will probably clean up. 1 Share this post Link to post Share on other sites
Mudrig150 386 #15 Posted June 8, 2019 One side is clean and a bit wore out but the other? Oof. Share this post Link to post Share on other sites
953 nut 66,557 #16 Posted June 8, 2019 (edited) From the looks of that intake valve I think we know where the water entered the cylinder. Edited June 8, 2019 by 953 nut Share this post Link to post Share on other sites
Mudrig150 386 #17 Posted June 8, 2019 It's wierd, there's no rust or corrosion in the intake but rust in the cylinder. That side had an open valve, and so did the other side but somehow the one side fogged itself... Share this post Link to post Share on other sites
ZXT 2,402 #18 Posted June 8, 2019 Do you own a hone? Roll that piston to the bottom of the cylinder and see how it cleans up. You never know.. The reason there isn't any rust or corrosion in the intake is because that's not where the water stood. 1 1 Share this post Link to post Share on other sites
Mudrig150 386 #19 Posted June 8, 2019 Nope. We had a hone but it's a 3 legged hone and its minimum size is 4 inches. The cylinder is something like 3.550. Share this post Link to post Share on other sites
Mudrig150 386 #20 Posted June 17, 2019 Finally got it to turn! Went to town with our little glaze breaker and after a bit managed to get it to turn all the way over. 3 Share this post Link to post Share on other sites
Mudrig150 386 #21 Posted June 21, 2019 So I cleaned up the bore a bit more, now the bore is nice and smooth enough, can't get the tiny raised edge out, but it's good enough. 1 Share this post Link to post Share on other sites
ZXT 2,402 #22 Posted June 22, 2019 5 hours ago, Mudrig150 said: So I cleaned up the bore a bit more, now the bore is nice and smooth enough, can't get the tiny raised edge out, but it's good enough. Raised edge at the top of the cylinder? That's just a ridge worn into the cylinder because the top ring doesn't go to the top of the bore.. Might indicate that the engine is pretty tired but won't affect anything as far as it turning over. Share this post Link to post Share on other sites
Mudrig150 386 #23 Posted June 22, 2019 It's a raised bit where the rust was. But it cleaned up really nicely, due to it being vapor rust and not water rust. Share this post Link to post Share on other sites
Mudrig150 386 #24 Posted June 22, 2019 Here's the improvement: Before After Just need to throw the heads back on and run er. (Note: That spot is rust staining, not pitting. It's slightly raised, not indented.) It's even still close in spec. Share this post Link to post Share on other sites
Mudrig150 386 #25 Posted July 5, 2019 Well after doing more work in this motor, such as getting the oil filter removed and getting some things adjusted. Still need to order my remote oil filter and get the heads back on. 2 Share this post Link to post Share on other sites
