Dadof2 5 #1 Posted May 28, 2019 Hi Everyone, Will a snow blower that fit on a c-81 and 416 fit on my 1971 Raider 10 tractor? Thanks, Dadof2 Share this post Link to post Share on other sites
Ed Kennell 47,614 #2 Posted May 28, 2019 Yes, it should it. Share this post Link to post Share on other sites
roadapples 6,987 #3 Posted May 28, 2019 My 72 Raider 10 doesn't have the front mule drive..... 1 Share this post Link to post Share on other sites
Ed Kennell 47,614 #4 Posted May 28, 2019 Thanks for pointing that out Jay. My Raider 12 has the front mule mount. I assumed all Raiders had the front mount. So if the blower has the frame mount kit, it should fit any tractor. If the blower has the front mule drive mounting kit, it will only fit tractors with front mule drives. 2 Share this post Link to post Share on other sites
pfrederi 21,225 #6 Posted May 28, 2019 The only difference between the tow styles is the length of the mounting bracket. 1st pic is frame mount 2nd is tachmatic. You could swap out the brackets if you found one or you could pick up a pair of side plates last picture that let you use front tachmatic stuff ( Front hitch accessory 8-5551) 2 Share this post Link to post Share on other sites
