Bear G 690 #1 Posted May 27, 2019 (edited) Good 60” Deck. Not rusted. One small crack at seam on corner. works fine. located in North Central Ohio. $450 firm. No trades. Barry G 419-681-4249 Edited May 28, 2019 by Bear G Trying to find the DELETE button.. Share this post Link to post Share on other sites
rjg854 12,862 #2 Posted May 27, 2019 @Bear G you should probably list this in the Classified section in the for sale area 1 Share this post Link to post Share on other sites
ztnoo 2,302 #4 Posted May 28, 2019 (edited) @Bear G Barry, Red Square is different than all the FB WH sites in its structure. Its not just blast away and all is good and all is OK here. Admittedly it takes a little time to learn that, but it does require some actual study of the forum structure (and rules, as well) here. If you do, this place will serve you well. btw, if you don't change your post location, it will likely be changed for you by a mod or Admin. Just a heads up. You are offering something for sale, the proper location is in Classifieds. Steve Edited May 28, 2019 by ztnoo 1 Share this post Link to post Share on other sites
Bear G 690 #5 Posted May 28, 2019 I would GLADLY delete if this site was a little more user friendly and I could actually figure out how to DELETE.. I remember why I don’t use this site. It’s more trouble than it’s worth. Way too aggravating for me.. Better things to do with my time than try to make sense of this train wreck. PLEASE delete it.. No offense intended.. just being honest. Share this post Link to post Share on other sites
ztnoo 2,302 #6 Posted May 28, 2019 (edited) @Bear G Barry, You yourself cannot delete your post or physically move your post. Only Admin or a Mod can do that. So, give up the idea you can delete what you created. That's a NO GO. That being said, your item still needs to go into Classifieds, and you CAN DO that, separate from the first problem. Just recreate the content of your original post in Classifieds, and Admin or a Mod will take care of this thread. Most of this site map is like learning the file structure of a computer. If you can do that, everything will make sense and you'll be fine. If you have no sense of the hierarchy of a PC and file structure, the smartest smartphone in the world isn't likely to help you. Edited May 28, 2019 by ztnoo Share this post Link to post Share on other sites
Mikey the Monkey 701 #7 Posted May 28, 2019 Don't worry bearg, you'll catch on. Don't leave. You have awesome customs. You don't Need to learn the file structure of a computer either. Have a great day friend! 1 Share this post Link to post Share on other sites
Sarge 3,470 #8 Posted May 28, 2019 The members here will gladly guide you on posting do's and don'ts, there is so much valuable information here it is worth your time. Sarge 1 Share this post Link to post Share on other sites
