Darkitec 4 #1 Posted May 26, 2019 (edited) I have the motor and ignition switch from a 1977 c-160 but I'm having a problem. I have no spark while the ignition switch is in the start position. And my ammeter gauge does not appear to have any movement. I do however have spark in the run position. Somethings is not adding up, and I'm trying to determine if I have a bad switch, or a wiring issue. Assuming a 4 over 1 orientation, looking at the back of the switch. in clock wise order, starting with the single blade, The diagram I could find indicates the blades should be S I A R B but if looking at the original wiring on the plug and using the wiring diagram for the 1977 c-120/c-160 tractor, the set up would indicate the blades should be S B A I R. Does anyone th the correct part number for the 1977 c-160 ignition switch and could you verify the alignment of the blades on the back of the switch. (this switch sadly has no markings on the back of it) or have other suggestions as to what my problem could be? I'm re-motoring a 1968 Raider 12 that has a big hole in the block. Edited May 26, 2019 by Darkitec Share this post Link to post Share on other sites
ebinmaine 79,518 #2 Posted May 26, 2019 (edited) The correct part number for that switches 103990. If you have a (5 blade) switch that is not labeled on the back please throw it away and don't use it. You have no idea if that's one for a magneto tractor or a battery ignition tractor. Edited May 28, 2019 by ebinmaine Added underlined content Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,323 #3 Posted May 26, 2019 The SBAIR switch may have 4 key positions. OFF- RUN with accessories - RUN only - START Part number 101917 replaced by 92-6785 Click on the picture SIARB is a switch with 3 key positions. OFF- RUN - START Part # 111216 replaced by 103990. Either switch should work with the wires in the correct locations. Garry 1 Share this post Link to post Share on other sites
Darkitec 4 #4 Posted May 27, 2019 2 hours ago, ebinmaine said: The correct part number for that switches 103990. If you have a switch that is not labeled on the back please throw it away and don't use it. You have no idea if that's one for a magneto tractor or a battery ignition tractor. I have the original magneto ignition switch from the Raider 12, the blade layout is completely different on it. I'm keeping it so that if I ever find a cheap magneto engine, I can reinstall it on the Raider. But I understand what you are saying. Share this post Link to post Share on other sites
Darkitec 4 #5 Posted May 27, 2019 (edited) 2 hours ago, gwest_ca said: The SBAIR switch may have 4 key positions. OFF- RUN with accessories - RUN only - START Part number 101917 replaced by 92-6785 Click on the picture SIARB is a switch with 3 key positions. OFF- RUN - START Part # 111216 replaced by 103990. Either switch should work with the wires in the correct locations. Garry This info is heaven sent, Thank you very much, You have cleared up some of my confusion. I have a 3 Position Switch currently, The original wiring is for the 4 Position Switch. Now to test the current switch to see if it conforms to the correct operation for 3 position connections. Of If I need to find a replacement switch. Edited May 27, 2019 by Darkitec 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,323 #6 Posted May 27, 2019 1968 Raider 12 model 1-6231 Early production used Kohler K301S-4712b with starter/generator and battery ignition Late production using Kohler K301S-47147b with Bendix starter, 10 amp alternator and magneto ignition with points and condenser Uses (~7572 3-terminal 3-position B-M-S) replaced by 101482 3-terminal 3-position B-M-S ignition switch Odd they made such a drastic change and used the same tractor model number. Click on the picture Garry Share this post Link to post Share on other sites
Darkitec 4 #7 Posted May 27, 2019 (edited) This is the factory switch that came on Grandfathers 1968 Raider 12 Magneto ignition. 4ga Power came from the battery to the switch and then from the switch directly to the starter. That's a lot of amps to run through a single switch for 50 years or so. Edited May 27, 2019 by Darkitec Share this post Link to post Share on other sites
953 nut 67,240 #8 Posted May 27, 2019 That is also a lot of potential for problems right behind your gas tank! You need to switch over to a battery ignition system anyway, why nod add a starter solenoid while you are at it? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,323 #9 Posted May 27, 2019 That switch was introduced in 1969 and was a retrofit for the 1968 models. Garry Share this post Link to post Share on other sites
ebinmaine 79,518 #10 Posted May 27, 2019 16 minutes ago, 953 nut said: You need to switch over to a battery ignition system anyway, why nod add a starter solenoid while you are at it? I'll second that. I haven't had great luck with the super cheap ignition switches. They just feel cheesy to me when I get them and last only a year or so... so I've stopped using them. Cole hersee brand, part number 24037 - BX. For the solenoid you can tell the parts store to look up something for a mid 70s Ford or Jeep. 3 post. 1 Share this post Link to post Share on other sites
Darkitec 4 #11 Posted May 27, 2019 21 minutes ago, 953 nut said: That is also a lot of potential for problems right behind your gas tank! You need to switch over to a battery ignition system anyway, why nod add a starter solenoid while you are at it? That's the plan, to swap over all the electrical components from the c160 to the Raider. 1 Share this post Link to post Share on other sites
Pullstart 70,447 #12 Posted June 13, 2019 On 5/27/2019 at 5:09 PM, ebinmaine said: For the solenoid you can tell the parts store to look up something for a mid 70s Ford or Jeep. 3 post. Don’t ya just love when you get a younger or less competent parts counter person and it’s easier to just make up a year make and model than to ask for a fender mounted solenoid? Share this post Link to post Share on other sites
ebinmaine 79,518 #13 Posted June 13, 2019 2 minutes ago, pullstart said: Don’t ya just love when you get a younger or less competent parts counter person and it’s easier to just make up a year make and model than to ask for a fender mounted solenoid? I do fully understand that we all need to learn how to do everything. Begins right at birth. There are a lot of jobs today however that are being made more and more intelligence proof or resistant. when I started as a parts counter person in 1992 we had 11 feet of catalogs on one side of the counter and some others underneath. When I started at a more modern store around 1998, nearly everything was on the semi useless computer system at that point. I can't even imagine what it must be like today. 1 Share this post Link to post Share on other sites
