TC10284 113 #1 Posted May 22, 2019 (edited) Is there a way to test proper function of the governor after replacing the plastic non-tabbed governor ball spacers in P220, P218, P216 engines, aside from it not over revving after 20-30min? Edited May 22, 2019 by TC10284 Share this post Link to post Share on other sites
520HC 208 #2 Posted May 22, 2019 Not really,but I always glue mine to the cam gear and they work fine. Share this post Link to post Share on other sites
lynnmor 7,949 #3 Posted May 22, 2019 Did you replace it with a tabbed one? If you replaced it with the same thing, all you can do is set the governed speed and then see if it holds over time. Share this post Link to post Share on other sites
TC10284 113 #4 Posted May 23, 2019 5 minutes ago, lynnmor said: Did you replace it with a tabbed one? If you replaced it with the same thing, all you can do is set the governed speed and then see if it holds over time. Yes, a tabbed one is what I used. Are you referring to this in regard to setting the speed? https://www.manualslib.com/manual/1223176/Onan-P216.html?page=27 I think I resolved the issues actually. Long story short, I'm experimenting on a 520H (with a P220g that is already burning oil from the rear intake valve seal) with a custom-made ball spacer using exact measurements of the original plastic spacer with extended tab. The one I made, the extended tab was thicker than the original. So I took it apart again this afternoon and ground down with a bench grinder on the extended tab on my custom made replacement and so far the test was good. It's back to 3600RPM. That, or I somehow missed the pin that goes in the governor cup the first time I put the replacement ball spacer in. But I saw no evidence of that. I'll test it again tomorrow and see how she does. But so far, so good. Share this post Link to post Share on other sites
lynnmor 7,949 #5 Posted May 23, 2019 19 hours ago, TC10284 said: Are you referring to this in regard to setting the speed? https://www.manualslib.com/manual/1223176/Onan-P216.html?page=27 On page 21 of that manual, the high speed stop is shown. You bend it till the engine runs 3600 RPM maximum. Share this post Link to post Share on other sites
