jonw440 226 #1 Posted May 20, 2019 The problem is while running the tractor at full throttle the engines starts to loose rpms. I have to push the throttle lever back to full throttle. This happens every few minutes or so. Any ideas on a fix? Share this post Link to post Share on other sites
Pollack Pete 2,273 #2 Posted May 20, 2019 Discussed here many,many times.I'd either peen the rivet that goes through the lever or drill out the rivet and replace it with a machine screw and double nuts or one lock nut.Easy fix for a pain in the a__ problem. 3 Share this post Link to post Share on other sites
peter lena 10,109 #3 Posted May 20, 2019 agree with above, with the machine screw adjustment, let you dial in what you want, pete 1 Share this post Link to post Share on other sites
ericj 1,580 #4 Posted May 21, 2019 I've had good luck using either vise grips or a pair of channel locks and squeezing the rivet tighter eric j 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #5 Posted May 21, 2019 ...same here. Share this post Link to post Share on other sites
