Goofey 89 #1 Posted May 20, 2019 (edited) Hi folks I am in need of a new electric pto clutch. I was hoping to find one that was just about the same design as the originals was. Anyone know of a source for souch a thing, that ain't TORO original. Those are so very expensive if at all available. Yes, I would preferre a new or rebuild unit if possible. No I would not convert to mechanical if available I have not been able to find one, so I'm hoping someone knows how. It's for a 1 1/8" shaft. Thanks Edited May 20, 2019 by Goofey Share this post Link to post Share on other sites
ebinmaine 77,125 #2 Posted May 20, 2019 You could place an ad in our wanted section and see if any members have a spare they'd like to sell. I've never had the experience of it but I understand to some extent they can be repaired or rewound. The option I would personally choose is to call Lincoln at A to Z tractor. One of our fine listed vendors. 1 Share this post Link to post Share on other sites
pfrederi 19,810 #3 Posted May 20, 2019 (edited) I have never seen an after market that could be used with out a lot of work if at all. What is wrong with your clutch. electrical or bearings??? Good used ones are not cheap. Edited May 20, 2019 by pfrederi Share this post Link to post Share on other sites
The Tuul Crib 7,340 #4 Posted May 20, 2019 15 minutes ago, ebinmaine said: You could place an ad in our wanted section and see if any members have a spare they'd like to sell. I've never had the experience of it but I understand to some extent they can be repaired or rewound. The option I would personally choose is to call Lincoln at A to Z tractor. One of our fine listed vendors. Share this post Link to post Share on other sites
953 nut 63,986 #5 Posted May 20, 2019 The most likely place to find a good used one would be on and any 1 1/8" electric clutch would work with a slight bit of modification. Warner makes most of what is out there so do a search for them. 1 Share this post Link to post Share on other sites
pfrederi 19,810 #6 Posted May 20, 2019 Looking at an Electric PTO from a JD I will revise my earlier comment it might be possible to use it but you would only have a single sheeve pulley. you would have to fabricate a bracket to hold it. You may also have an issue with clearance around the drive pulley (belt to the transmission). The JD pulley center would hit the drive pulley. The WH version the center hub of the PTO rides against the drive pulley. You may be able to solve that with spacers but I am not sure. WH is on the left. 1 Share this post Link to post Share on other sites
Goofey 89 #7 Posted May 20, 2019 36 minutes ago, 953 nut said: The most likely place to find a good used one would be on and any 1 1/8" electric clutch would work with a slight bit of modification. Warner makes most of what is out there so do a search for them. OK, so what modefications, and wich to chose. CW or CCW. I'm not sure here And I don't see any of the warners that looks anything like the original. Is that just not available? Share this post Link to post Share on other sites
Goofey 89 #8 Posted May 20, 2019 14 minutes ago, pfrederi said: Looking at an Electric PTO from a JD I will revise my earlier comment it might be possible to use it but you would only have a single sheeve pulley. you would have to fabricate a bracket to hold it. You may also have an issue with clearance around the drive pulley (belt to the transmission). The JD pulley center would hit the drive pulley. The WH version the center hub of the PTO rides against the drive pulley. You may be able to solve that with spacers but I am not sure. WH is on the left. I also have been thinking that it could be made to fit. Only problem is the design/looks of it. thats why I hoped for a more original looking unit. The old one is ratteling, and it has begun cutting out, so from other threads, I gather it's just a matter of time to meltdown. I have located a nice original unit, but it is more expensive that a new heavy duty unit, and still 40 years old. Share this post Link to post Share on other sites
Goofey 89 #9 Posted May 20, 2019 Could one take the coil and "discs" from a new unit, and fit them into the old housing? Share this post Link to post Share on other sites
pfrederi 19,810 #10 Posted May 20, 2019 Virtually all of the new Electric PTOs are designed to run a deck on vertical shaft engines and thus are some what the reverse of the WH. The coil is mounted close to the engine on new ones with pulley out board. WH are just the opposite. I have no idea if you could swap coils. I doubt very much you will find anything new that "looks" like original Bearings are not hard to replace. 1 1 Share this post Link to post Share on other sites
daveoman1966 3,881 #11 Posted May 20, 2019 (edited) I have a good used Electric PTO...looks like this... Edited May 20, 2019 by daveoman1966 1 Share this post Link to post Share on other sites
Skipper 1,790 #12 Posted May 20, 2019 Can I ask what the price would be on that. I might be interested if Goofey ain't. 1 Share this post Link to post Share on other sites
ztnoo 2,302 #13 Posted May 20, 2019 @Skipper, I believe Dave prefers to conduct price discussions privately. I suggest using PM here at Red Square or emailing him : daveoman@windstrream.net 1 Share this post Link to post Share on other sites
Redhorse 12 #14 Posted May 20, 2019 I have an electric PTO from a Wheel Horse 268H. Not sure if you could use something like that. Let me know if that would work. Share this post Link to post Share on other sites
daveoman1966 3,881 #15 Posted May 20, 2019 (edited) 1 hour ago, ztnoo said: @Skipper, I believe Dave prefers to conduct price discussions privately. I suggest using PM here at Red Square or emailing him : daveoman@windstrream.net I've been admonished in the past for posting prices in the RS open forum. Accordingly, I ask members to send me an email for item(s) pricing details.. without intent to deceive or offend. Edited May 20, 2019 by daveoman1966 1 1 Share this post Link to post Share on other sites
953 nut 63,986 #16 Posted May 20, 2019 31 minutes ago, daveoman1966 said: I've been admonished in the past for posting prices in the RS open forum. Accordingly, I ask members to send me an email for item(s) pricing details.. without intent to deceive or offend. Dave, you have come to the rescue of lots of us over the years by providing a quick response and an offer to supply needed parts. You also have a lot of great information to share. 1 Share this post Link to post Share on other sites
daveoman1966 3,881 #17 Posted May 21, 2019 3 hours ago, 953 nut said: Dave, you have come to the rescue of lots of us over the years by providing a quick response and an offer to supply needed parts. You also have a lot of great information to share. Thanx, I try....but you know as well as I do... its an addiction. lol. 2 Share this post Link to post Share on other sites
tinker7 1 #18 Posted May 23, 2019 HI, I RAN A CROSS THIS FORUM WHILE LOOKING FOR AN ELECTRIC CLUTCH FOR MY 1972 12HP RAIDER 8 SPEED. I AM LOOKING FOR A REPLACRMENT. MY OLD ONE SEEMS TO HAVE AN OPEN IN THE COIL. ANY HELP WOULD SURE BE APPRECIATED. THANKS RON Share this post Link to post Share on other sites
pfrederi 19,810 #19 Posted May 23, 2019 2 hours ago, tinker7 said: HI, I RAN A CROSS THIS FORUM WHILE LOOKING FOR AN ELECTRIC CLUTCH FOR MY 1972 12HP RAIDER 8 SPEED. I AM LOOKING FOR A REPLACRMENT. MY OLD ONE SEEMS TO HAVE AN OPEN IN THE COIL. ANY HELP WOULD SURE BE APPRECIATED. THANKS RON Check with A to Z tractors in our vendors section or with daveoman1966 (posted above) https://www.wheelhorseforum.com/forum/92-vendors/ Welcome to red square Share this post Link to post Share on other sites
tinker7 1 #20 Posted May 25, 2019 Thanks PFREDERI, A-Z was able to help. I really appreciate the tip. 1 Share this post Link to post Share on other sites
