Kate 5 #1 Posted May 16, 2019 I'm new to this mower stuff. I got it started and mowed once. This time, got it started and pushed the lever to engage the blade and it screeched so loud and horrible! I turned it off. This did not happen last time. Help please. Share this post Link to post Share on other sites
JAinVA 4,638 #2 Posted May 16, 2019 With everything off, check to see if the blades rotate freely.It sounds like the main drive belt slipping because of a bad spindle bearing or something preventing the blades from rotating. 1 Share this post Link to post Share on other sites
adsm08 3,967 #3 Posted May 16, 2019 1 minute ago, JAinVA said: With everything off, check to see if the blades rotate freely.It sounds like the main drive belt slipping because of a bad spindle bearing or something preventing the blades from rotating. I second the motion. A few weeks ago I watched/heard/smelled the guy two doors down smoke his spindle belt after clogging his deck with grass clippings to the point where one blade couldn't turn. We dropped his deck, cleaned it, grease it, and put a new belt on. He had to make a few passes, lowering the cut height each time, but he got her done eventually. Take the deck off if you can, pull it out, inspect and clean the under side, make sure all the blades spin freely by hand, and get everything with a fitting greased. An old and/or worn belt can also make a nasty noise because it just can't grip well, so if the belt is more than a year or two old, or if it came from TCS just replace it while you are there. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #4 Posted May 16, 2019 1 hour ago, adsm08 said: I second the motion. A few weeks ago I watched/heard/smelled the guy two doors down smoke his spindle belt after clogging his deck with grass clippings to the point where one blade couldn't turn. We dropped his deck, cleaned it, grease it, and put a new belt on. He had to make a few passes, lowering the cut height each time, but he got her done eventually. Take the deck off if you can, pull it out, inspect and clean the under side, make sure all the blades spin freely by hand, and get everything with a fitting greased. An old and/or worn belt can also make a nasty noise because it just can't grip well, so if the belt is more than a year or two old, or if it came from TCS just replace it while you are there. To 1 Share this post Link to post Share on other sites
clueless 3,345 #6 Posted May 16, 2019 Last time I used my JD was in Feb. to vac up some leaves, everything worked fine. Saturday started to to a little trimming turned on the pto , idler pulley froze up, it can happen quick. 1 Share this post Link to post Share on other sites
Kate 5 #7 Posted May 16, 2019 4 hours ago, adsm08 said: I second the motion. A few weeks ago I watched/heard/smelled the guy two doors down smoke his spindle belt after clogging his deck with grass clippings to the point where one blade couldn't turn. We dropped his deck, cleaned it, grease it, and put a new belt on. He had to make a few passes, lowering the cut height each time, but he got her done eventually. Take the deck off if you can, pull it out, inspect and clean the under side, make sure all the blades spin freely by hand, and get everything with a fitting greased. An old and/or worn belt can also make a nasty noise because it just can't grip well, so if the belt is more than a year or two old, or if it came from TCS just replace it while you are there. I had to clear a big bunch of leaves by the pulleys-belts?. It was bad. Thank you for the info. I truly appreciate it! 2 Share this post Link to post Share on other sites
JAinVA 4,638 #8 Posted May 16, 2019 Glad you got it sorted out.I can personally say that I appreciate you letting us know that you got it fixed and what the problem was. Share this post Link to post Share on other sites
Guest 88vic #9 Posted May 16, 2019 If the Pto clutch tension (on the disc) isnt properly tight enough it will squeal as well. Easy to adjust, pull the pin and adjust the eyelet on the control rod. Be careful not to go too tight or premature bearing failure can happen. There is a proper way to adjust, maybe someone else can explain, I just go by feel but ive been around these machines for awhile. Share this post Link to post Share on other sites
Guest 88vic #10 Posted May 16, 2019 Kate , youve found the right place to be, the folks here on Red Square are the best. Its like going back to your old hometown, everyone knows everyone and always people to lend a helping hand. Ive made forever friends here for sure ! Welcome to Red Square, it wont be long before you get "Horse Fever". Share this post Link to post Share on other sites
Tuneup 1,452 #11 Posted May 18, 2019 Is your cat missing? They get into the strangest places. Ours used to like to sleep near the engine fan - had to pop the hood before heading out and you'd get that loud scream and a flash of fur if you didn't. Amazing that cat lived all those years. With the belt as loose a possible, try to spin the mower pulley. It should spin slowly to a stop after you get it going. If not, grass clogged or bad spindle bearings or something under the deck. The idlers also tend to freeze and can be manually spun. It's one or more of these and these machines are so easily diagnosed! Good luck! Share this post Link to post Share on other sites
