jammankel 24 #1 Posted May 5, 2019 the motor is making a horible noise and i dont know what it is it happens roughly every 40 feet and when you idle it down it smooths right out Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,276 #2 Posted May 5, 2019 Have another condenser you can try? If not disconnect the one on there and try it. Garry 1 Share this post Link to post Share on other sites
jammankel 24 #4 Posted May 5, 2019 (edited) so i swapped the condenser and it is still happening do you guys believe it is spark knock i plan on resetting the points gap tomorrow could it be the coil? thanks for any help Edited May 5, 2019 by jammankel Share this post Link to post Share on other sites
953 nut 66,570 #5 Posted May 5, 2019 24 minutes ago, jammankel said: resetting the points gap That sets your timing too. Share this post Link to post Share on other sites
Sarge 3,471 #6 Posted May 9, 2019 That is either spark knocking or the carb is getting plugged and starving it for fuel - mine did the same thing the last time I mowed but haven't had the time to get out to fix the thing yet. That 16 needs a lot of fuel and the timing set correctly to be happy - look into doing the K series timing procedure with a multi-meter. Generally - called "Static Timing" procedure. Sarge 2 Share this post Link to post Share on other sites
Hacksawhero123 351 #7 Posted May 10, 2019 Yeah. Don’t set the points with a feeler gauge. Static timing is the way to go. Mark. 1 Share this post Link to post Share on other sites
seven 202 #8 Posted May 11, 2019 Can you explain to me what static timing is cause I've never heard of it. Share this post Link to post Share on other sites
jammankel 24 #9 Posted May 11, 2019 i dont know what it is but i set the points and all seems well at the moment Share this post Link to post Share on other sites
953 nut 66,570 #10 Posted May 11, 2019 10 hours ago, jammankel said: i dont know what it is but i set the points and all seems well at the moment Kohler static_timing.pdf 1 Share this post Link to post Share on other sites
Hacksawhero123 351 #11 Posted May 12, 2019 My k341 was set a bit too far advanced and was running hot. My exhaust elbow and stack tip was cherry red hot. After retiming, she ran cooler and all was well in the world again. Use an ohm meter. You want the points to break contact at the same point that the “S” timing mark on the flywheel lines up with the pointer. Best of luck. Mark 1 Share this post Link to post Share on other sites
Hacksawhero123 351 #12 Posted May 12, 2019 A good sign that your timing might be a fuzz off. Mark. 1 Share this post Link to post Share on other sites
