snowhound 106 #1 Posted May 4, 2019 I recently picked up a pair of 23x10.50x12 Deestone Bar tread tires what width rim should I be mounting them on? Share this post Link to post Share on other sites
dells68 7,499 #2 Posted May 4, 2019 8.5” is probably best, but I’ve mounted some on 7.5” wide rims with no problem - they just bulge a little more and the lugs may not lay as flat. 1 Share this post Link to post Share on other sites
JAinVA 4,638 #3 Posted May 4, 2019 (edited) They can be mounted on the 7.5" width rim.I bought a set of Carlisles that size that were mounted on 7.5" rims but they looked wrong.I mounted them on 8.5" 520 rims and they look great. Edited May 4, 2019 by JAinVA 1 Share this post Link to post Share on other sites
pfrederi 19,894 #4 Posted May 4, 2019 Deestones run small so you could get away with 7.5" 3 Share this post Link to post Share on other sites
rjg854 12,847 #5 Posted May 4, 2019 8 hours ago, snowhound said: I recently picked up a pair of 23x10.50x12 Deestone Bar tread tires what width rim should I be mounting them on? We want when you get them mounted, especially if you mount them on the 7.5" rims Share this post Link to post Share on other sites
The Tuul Crib 7,340 #6 Posted May 4, 2019 I put some deestone 10.50 on 7.5 rims and they fit great! 2 Share this post Link to post Share on other sites
JAinVA 4,638 #7 Posted May 4, 2019 (edited) Those Deestones look fine on a 7.5".The same size Carlilses look cartoonish on 7.5"Here they are on 8.5" rims. Edited May 4, 2019 by JAinVA 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #8 Posted May 4, 2019 (edited) For the price you can’t beat the deestones lmo . Even 8.50 on 6.00 inch rims look great!! Edited May 4, 2019 by The Tool Crib 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #9 Posted May 4, 2019 I did the same with my 315-8 Nanco/Deestone 23x10.50-12 on 7.5" rims... 2 Share this post Link to post Share on other sites
snowhound 106 #10 Posted May 4, 2019 Thanks for all of the replies I'll use the 7.5" rims that I already have and since I have two extra sets of 7.5" rims I'll order another pair of tires. 2 Share this post Link to post Share on other sites
