Retired Wrencher 6,256 #1 Posted April 30, 2019 Hi This goes between the lift arm on tractor and the plow with pins and clips. Does any one have the dimensions this part ? would like to make one up. Should not be that difficult to make. I do not like the chain set up on it now. Thanks in advance. Share this post Link to post Share on other sites
ebinmaine 76,471 #2 Posted April 30, 2019 Gary I've got one on the plow that I use for my B and C series tractors. I can measure it for sure when I get home but I feel like it's made out of steel that's about 1 1/4 or 1 1/2 in wide. 1/8 in or 3/16" thick would be fine. Total length is 11.25 and the pin Center is somewhere around 10 or 10 .25. 1 Share this post Link to post Share on other sites
ebinmaine 76,471 #3 Posted April 30, 2019 Handy for down pressure. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,917 #4 Posted April 30, 2019 Would it be a little over 5" long with the holes centered on about 4"? https://www.partstree.com/parts/toro/parts/105052/ Garry Found this. Click on the drawing. 2 Share this post Link to post Share on other sites
daveoman1966 3,881 #5 Posted April 30, 2019 Buy a NEW part 105052 here for less than $20. .. https://www.psep1.biz/arinet.asp?aribrand=TO#/s/TO//105052/1/ Share this post Link to post Share on other sites
Retired Wrencher 6,256 #6 Posted May 1, 2019 (edited) 22 hours ago, ebinmaine said: Handy for down pressure. Thanks Eric. I would like to see a pic of it so I know this right part. Edited May 1, 2019 by Retierd Wrencher Share this post Link to post Share on other sites
Retired Wrencher 6,256 #7 Posted May 1, 2019 20 hours ago, daveoman1966 said: Buy a NEW part 105052 here for less than $20. .. https://www.psep1.biz/arinet.asp?aribrand=TO#/s/TO//105052/1/ Thanks D but no pick of it. I hope this is the right part. Share this post Link to post Share on other sites
Retired Wrencher 6,256 #8 Posted May 1, 2019 22 hours ago, gwest_ca said: Would it be a little over 5" long with the holes centered on about 4"? https://www.partstree.com/parts/toro/parts/105052/ Garry Found this. Click on the drawing. Thanks Garry. This not clear if this is the right part. I do not see the lift holes. Share this post Link to post Share on other sites
Retired Wrencher 6,256 #9 Posted May 1, 2019 Eric is this the part? Just need length of part and distance between holes Thanks. Share this post Link to post Share on other sites
ebinmaine 76,471 #10 Posted May 1, 2019 8 minutes ago, Retierd Wrencher said: Eric is this the part? Just need length of part and distance between holes Thanks. Gary, mine is the longer one. That one looks more like Garry above is describing. 5.5 inches maybe. I'd go by the blueprint for the shorter of the two that he posted. The one I have is for a slightly different setup and does not use the horizontal bar such as in that picture. It goes directly up to the lift lever. Share this post Link to post Share on other sites
Retired Wrencher 6,256 #11 Posted May 1, 2019 2 minutes ago, ebinmaine said: Gary, mine is the longer one. That one looks more like Garry above is describing. 5.5 inches maybe. I'd go by the blueprint for the shorter of the two that he posted. The one I have is for a slightly different setup and does not use the horizontal bar such as in that picture. It goes directly up to the lift lever. Ok thanks Eric. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,917 #12 Posted May 1, 2019 This photo is of the short link on a 1" square grid. https://www.partstree.com/parts/toro/parts/105052/ If you click on the drawing above it will take you to another picture of how they are used. Garry Share this post Link to post Share on other sites
Retired Wrencher 6,256 #13 Posted May 1, 2019 (edited) 3 minutes ago, gwest_ca said: This photo is of the short link on a 1" square grid. https://www.partstree.com/parts/toro/parts/105052/ If you click on the drawing above it will take you to another picture of how they are used. Garry Thanks Garry. I see it now in the drawing . Need more coffee. Edited May 1, 2019 by Retierd Wrencher Share this post Link to post Share on other sites
