Pullstart 71,157 #1 Posted April 29, 2019 Frank barely looks like Frank. It’s pretty much a Charger 12 right now but it’s getting a bath! I have a drip that runs from the transmission forward onto the frame. I assume it is coming from the motion control shaft, am I correct to assume it may be just that? If so, how does the dash tower separate from the motion control? Do I simply unbolt the dash stand and lift it straight up? Share this post Link to post Share on other sites
pfrederi 21,095 #2 Posted April 29, 2019 To replace the motion control O rings i go ahead and split the tractor. That gives you access to drive out the roll pin, then maybe have to fight to get the lever off and finally use your 12 pt socket to get the bolts holding it on to the pump housing. The o rings sizes aer in the pinned post on Sudsrtrand O rings. I have them if you want just give me your address I will mail you a pair. 1 Share this post Link to post Share on other sites
Pullstart 71,157 #3 Posted April 29, 2019 2 minutes ago, pfrederi said: To replace the motion control O rings i go ahead and split the tractor. That gives you access to drive out the roll pin, then maybe have to fight to get the lever off and finally use your 12 pt socket to get the bolts holding it on to the pump housing. The o rings sizes aer in the pinned post on Sudsrtrand O rings. I have them if you want just give me your address I will mail you a pair. When I pull the dash tower, will the plastic part of the motion control slide right up and out, or is there more to it that I cannot see? I saw your gasket chart, there must be an inner and outer seal? Thank you for the offer, I’d like to shake your hand for that, hopefully at the big show! It seems there was a thread on a complete teardown of this trans, but I couldn’t find it last time I searched. Share this post Link to post Share on other sites
oldredrider 2,553 #4 Posted April 29, 2019 You don't need to pull the dash tower. By unbolting the transmission from the frame, you'll be separating the motion control from the transmission. Once you get that separated, you'll have easy access to the cam plate and associated seals and such. 2 1 Share this post Link to post Share on other sites
pfrederi 21,095 #5 Posted April 29, 2019 I should ad you do not need to disconnect the hydro hoses from the lift valve there is enough slack just roll the rear end back and turn it slightly. 1 Share this post Link to post Share on other sites
Pullstart 71,157 #6 Posted May 16, 2019 Paul, thanks again for your care package! Thanks for the spares too! The big o-ring is about 1/2 the thickness and the small one is rock hard. Is wheel bearing grease sufficient for the slide assembly? 1 Share this post Link to post Share on other sites
pfrederi 21,095 #7 Posted May 16, 2019 I do not lube my slider ...but I am not sure if I am correct. 1 1 Share this post Link to post Share on other sites
Sarge 3,473 #8 Posted May 27, 2019 If you lube it - you run the risk of it running away even more than usual. The nylon cam is designed to lubricate itself - so no grease needed. Sarge 2 Share this post Link to post Share on other sites
Pullstart 71,157 #9 Posted June 6, 2019 I believe I read that the transmission capacity is 2 qts. Does that include the hydraulic system? Also, this jug of Lucas oil stabilizer says it’s good for ATF as well. Could I add a bit to the transmission too then? Share this post Link to post Share on other sites
pfrederi 21,095 #10 Posted June 6, 2019 (edited) All one system and if it is emptied out it needs 5 qts. I do not use snake oils so I can't can not comment on the Lucas stuff. if i was going to blow the extra money i might go with Synthetic ATF. All 5 of my Chargers work just fine on dead dinosaur ATF Edited June 6, 2019 by pfrederi 2 Share this post Link to post Share on other sites
953 nut 68,790 #11 Posted June 6, 2019 7 hours ago, pullstart said: the transmission capacity is 2 qts. That would be correct for a six or eight speed. 1 Share this post Link to post Share on other sites
