Pullstart 68,988 #1 Posted April 29, 2019 I am fixing to build an e tank bigger than my previous 5 gallon bucket. I have a few steel drums and some plastic containers as well. If a steel drum is used, I’ll be sure to prevent the part from grounding out by means of a plastic grate or otherwise. My question: Does the anode placement in the tank have any effect on the reaction of electrolysis? I.E. could I toss a brake rotor in the bottom of a plastic tank and it will work the whole part? Also, do multiple anodes increase the reaction? Share this post Link to post Share on other sites
oliver2-44 11,272 #2 Posted April 29, 2019 I've used a plastic 55 gal barrel with one anode for quite a while with good success. To me it seems surface area is important. i usual use a scrap piece of heavier sheet metal or plate. Probable about the size of two brake drums. I find it speeds the process if I lift the part and the anodes at least one a day and brush them off with a stiff nylon brush . So what are you about to cook? Share this post Link to post Share on other sites
JAinVA 4,638 #3 Posted April 29, 2019 (edited) In my experience with an e-tank the anode should face the part to be cleaned.I have used 5gallon plastic buckets and a plastic 100 gallon horse through.I am thinking about using a metal 5 gallon bucket filled with electrolyte as an anode and suspend the part to be cleaned inside it to get the part cleaned on all sides at the same time.I use lye in the water as an electrolyte and it will desolve paint real well. Edited April 29, 2019 by JAinVA Share this post Link to post Share on other sites
Pullstart 68,988 #4 Posted April 29, 2019 6 minutes ago, oliver2-44 said: So what are you about to cook? Frank Share this post Link to post Share on other sites
pfrederi 19,972 #5 Posted April 29, 2019 I use scrap disc brake rotors in a plastic 55 gal drum Share this post Link to post Share on other sites
formariz 12,356 #6 Posted April 29, 2019 "Line of sight" is important in anode placement. Surface area also increases efficiency greatly. That coupled with increased voltage can make it much faster. I use a battery in conjunction with a charger. Have also made "special" tanks for difficult parts with like internal chambers such as the beams on Emmert vises. Stay away from the metal container. It will create many difficulties and its just not safe. 1 1 Share this post Link to post Share on other sites
Pullstart 68,988 #7 Posted April 29, 2019 I’ll likely use this half barrel or blue trash bin then. They both will fit more than 2/3 of a belt guard, likely the same scenario if I dip a frame. Plus I can get away with less cooking juice. Thanks fellas! 2 Share this post Link to post Share on other sites
Pullstart 68,988 #8 Posted April 29, 2019 This autta’ do the trick! 1 Share this post Link to post Share on other sites
The Tuul Crib 7,347 #9 Posted April 29, 2019 2 hours ago, pullstart said: This autta’ do the trick! How about an old fiber glass bath tub. That would big enough to submerse larger pieces. Share this post Link to post Share on other sites
Pullstart 68,988 #10 Posted April 29, 2019 1 minute ago, The Tool Crib said: How about an old fiber glass bath tub. That would big enough to submerse larger pieces. That would mean I need to haul more junk home! 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #11 Posted April 29, 2019 More junk is a plus . More places to hide from the wife. 1 2 Share this post Link to post Share on other sites
